Query about the timer in VS8
Keith C
Post by Keith C »
Can someone tell me why there is discrepancy as follows...
I drop an image clip in the time line (default duration 5 secs).
The timer at top left of screen says it is 5 secs... bit when the clip is played, the timer at bottom right of preview window shows only 4.24 secs.
Similarly if I drop another 5 sec image next to the 1st image (no transitions, just 2 image clips) the timer at top left says 10 seconds and playing the project once again gives a total of 9.24 secs.
BUT if I drag the jog bar across the images manually then the 2nd clip comes in after 5 secs indicating that the 1st clip is 5 secs long.
I hope I have explained this properly.I 'm baffled!
THoff
Post by THoff »
It's not 4.24 seconds, it's 4 seconds and 24 frames. You're in PAL land, where every second has 25 frames.
Keith C
Post by Keith C »
Lol. Thanks Torsten...
Would I seem picky if I asked why it doesn't show 4.25 then?
Or even 5.00?
Thanks for your quick reply.
THoff
Post by THoff »
Because the first frame is at 0 seconds plus 0 frames, the last of the 25 frames in the first second would thus be at 0 seconds plus 24 frames.
If you are at 1 second plus 0 frames, your video is actually 26 frames long.
As for the original question regarding the missing second, do you have a transition on either side of the image? That might cut away a bit of the image duration at either end...
