I did install the DVC90 vista driver (NO success)
I did install vista package for UVS9.0 (NO success)
I dont know why the UVS90 doesnt recognize the DVC90 audio device
PLZ, I need your support in this strange situation.
with regards
There is no such 'package' for VS9. VS9 is not compatible with Vista, period. There is a 'package' for VS10 which sort of makes it work with Vista. But don't expect VS9 to work properly...I did install vista package for UVS9.0 (NO success)
No sir, I'm using UVS 10.0. I used this product on XP and it is working very fine. However, when I switched to Vista, there is no incoming sound from dazzle Digital Video Creator 90.vidoman wrote:So did you try to install a patch meant for VS10 on VS9, or are you actually using VS10?
I would at this point recommend doing a complete un-install/re-install. Ulead programs leave a lot of files behind. So just doing a simple add/remove programs from the control panel and then re-installing may not correct some issues. Instructions can be found here : Re-installation of Ulead Products
Once that is done Try some of the solutions provided on Vista Help Page for getting older programs to run on Vista.
You might get VS9 to run on Vista, however there is no guarantee that it will be stable. VS9 uses the VFW(Video For Windows) and DirectShow, where as these may not be supported in Vista.
I did visit the Pinnacle website - which produces Dazzle products-. I did download the Vista version for the Dazzle. NOTHING changed.Ken Berry wrote:It is almost undoubtedly a driver issue. Have you visited the Dazzle website to see if they have brought out a new audio driver which is compatible with Vista?
