WinDVD 9 Install problems - IVIVIDEO.AX
Moderator: lata
Patrick1978
I was getting this same error message when installing WinDVD 9 on a fresh install of Windows XP with Service Pack 3.
I fixed it by updating DirectX
DirectX End-User Runtime Web Installer
Same here, I had recently installed SP3 on XP, and installed Corel WinDVD was getting the same error code. So, I uninstalled WinDVD 9...installed Direct X June 2008, and then reinstalled WinDVD 9 without any problems...
no need to copy the IVIVIDEO.ax file
no need to dump temp files and folders
no need to edit the registry
so PATRICK1978's solution is the SOLUTION...over and out.
Good work.
Good work.
Own your burden and pass on hope to the next generation.
carmsantoro
Same Same Problem as Gary
What can I do next to make this work??
- ram: 2 GB
- sound_card: Intel GMA 950
Hopefully I have done this right
Try This Link for a copy of IVIVIDEO.ax
carmsantoro
- ram: 2 GB
If you think that file is causing your problem the first thing I would try is to replace your existing one with the one from my download link.
If that does not get it working again then try uninstalling/re-installing WinDVD. Note also the other posts that mention updating to the latest version of DirectX
Patrick1978
Installing the DirectX update that I linked to in my previous post is also required on Windows Vista and Windows 7 (or at least it's required for the Release Candidate) in order for WinDVD 9 to install properly.
It was also required for WinDVD 8 but the installer would actually warn you if you needed it before it would let you install, which is how I figured out that I needed to update DirectX since all the other "solutions" in this thread were completely useless.
The update should be installed BEFORE installing WinDVD.
If you have already installed WinDVD then uninstall it, then install the DirectX update, then reinstall WinDVD.
Also note that the link I posted should always point to the latest DirectX update which is updated every few months.
carmsantoro
DirectX
I do not appear to have DirectX on my machine. Where can I get a clean version and what is the latest complete rev??
carmsantoro
