Which Scart?
Moosey
Which Scart?
Post by Moosey »
I'm trying to capture via a scart connected to my video's AV output. However, the scart only has yellow and white leads and Videostudio cant detect a signal.
Do I need another scart with all 4 leads? (i.e yellow,white, red and S video)
leezy2
Post by leezy2 »
Shouldn't be a problem so long as you don't mind mono audio on what you record. The problem with VS not seeing it is most likely to do with how the signal is getting into the computer, but there is no detail about your capture/video card on your posting. How are you connecting your video to the PC, and are you UK or other?
Moosey
Which Scart
Post by Moosey »
Sorry, should have said.
I'm in the UK and am connecting my scart via Easy Cap USB 2.0.
Video card is NVIDIA MCP67M
Cheers
leezy2
Post by leezy2 »
OK, I'm assuming you are getting no capture at all. Can VS see the USB capture device? If it can, and you just are not getting a signal, have you got a 'SCART Out' or 'bi-directional SCART' lead? Some of them only work one way! If VS cannot see the USB device, check the device is there in the device manager bit of your 'system' info in control panel (assuming XP or the like, I have no experience of Vista!). If it's not there try re-installing the capture device and run VS again. (what version of VS are you using?)
Moosey
Which Scart
Post by Moosey »
Hi Leezy2
Yep it looks like I need a SCART to PHONO out adaptor. I'll try reinstalling my capture device as well.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
most scarts are only wired for one way travel, you need a two way fully wired scart, which should have a switch on it for changing the signal from in to out.
