Cannot increase gif size when SAVE -- all gifs jagged
JennyPats
Post by JennyPats »
I know this is basic -- but I'm desperate.
When I develop a new gif and do a "Save As" -- my system suddenly saves it at the absolute lowest resolution and the gif is pixelated like crazy.
I've tried chaning every setting I can find, to no avail.
HELP -- much appreciated!!!!!!!!!!!!!
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
More details, please...
Saving with PI or GIF Animator? If PI, which version?
What settings are you using, and exactly what are the steps you are making as you're saving?
Please remember we can't read minds, and have no idea specifically what you have tried, so trying to offer advice when we have no idea what you've tried, etc. is pretty tough. Much like asking you if you like the shirt I'm wearing right now... :wink:
JennyPats
Post by JennyPats »
Version ULEAD 8
I used to be able to save at higher resolutions... now
With the .gif displayed -- "Save As"
Ulead GIF Image Optimizer screen is displayed with these settings:
Preset: {Current] Index Optimized
colors: 256
weight: green
pallette: optimized
soft: 10
file type: indexed
lossy (unchecked)
dither: 10%
inerlace: (unchecked)
THANK YOU!!
VikingAnimations
ram: 4 GB
256 colors is, of course, the maximum allowed by the GIF format. If you want a full range of colors, GIF format is not so good. The more colors the image has, and the wider the range, the worse the GIF format will make it appear.
From the Help file:
Soft - Select a level to determine the amount of blur that will be applied to your image. The higher the number, the smoother your image appears. This facilitates compression and compensates for any dithering you've previously applied to your image.
Have you tried this set to none?
Weight, that depends on the image and your taste, but Even should work.
Dither should likely be set to 100.
You didn't mention if this one is transparent or not.
JennyPats
THANK YOU
Post by JennyPats »
OMG
Here's the deal -- the "Dither" has a 2 digit window -- so I thought it could only be set to the max of 10% when it could actually be set to 100%
(I didn't read the settings displayed on the right correctly)
Set it to 100% after reading your suggestions -- IT'S FIXED.
THANK YOU SO MUCH!!!
PS
Great shirt... and, seriously thanks for taking time with this -- I REALLY needed those .gifs !!
