memory leak again?
gordon_fan_24
memory leak again?
Post by gordon_fan_24 »
I installed the upgrade to VS9, from VS7 SE, and after 15 mins I get an "out of memory" message, I downloaded the trial of VS8 in January, and got the same thing, but I knew that it was a bug in VS8 and had been fixed in a patch. Why would they let the same bug appear in their newest version? and how can I fix it?
jchunter
Post by jchunter »
I've been monitoring memory usage in VS9 and have only seen it much better behaved than 8.01.
What were you doing just before the crash? See if you can repeat it. If so, I will try the same thing.
BTW, what are your computer specs?
John
gordon_fan_24
I was just cutting out some commercials out of a TV program, It was a long program and took me about 3 hours to cut, I had to reboot the program, or my computer about 15 times in that time period, due to the memory problem. My specs are 512 mb RAM, 3.4 Ghz, 250 Gb, Hard Drive, It was the only program running at the time, I got about 10-20 mins before the memory ran out in each session
jchunter
Post by jchunter »
Gordon,
Were you cutting with save trimmed video, multi-trim video, or the sicsors? Was it mpeg or AVI? Please post the complete property list.
John
gordon_fan_24
I am not at my editing computer right now, but I can tell you that I was using the scissors, it was MPEG-2 captured using ADS tech DVD Xpress, at 9mbps,
I will post the complete property list when I get to that computer
gordon_fan_24
Here are the properties that I could locate
MPEG-2, Upper field first
24 bits, 720 x 480, 4:3
NTSC drop frame 29.97fps
data rate max 8999kbps
Audio
48Khz, 16 bit Stereo
bitrate: 224kbps
If I missed anything, let me know and I'll try to find it
jchunter
Post by jchunter »
Gordon,
I pulled up an old analog SVHS capture at similar capture settings except at 8000kbps bitrate. One thing I noticed is that during instant playback, the mrmory runs up to about 490 MB and drops back to 300 - 320. The high number is uncomfortably close to your 512 MB installed memory. I don't know if the amount of memory acquired is proportional to the amount installed (I have 1 GB) I have the virtual (paging) memory limit at 1 GB. Could you try setting your memory to 512MB and then monitor mem usage..
John
Edit: Another thought: Your video frames are larger because of the higher bitrate. Just a few percent larger might push your system intp page thrashing mode...
gordon_fan_24
I am not quite sure what you mean by "setting the memory to 512, I assume that is what I am running with. and I am not computer literate in that area of computers.
jchunter
Post by jchunter »
Gordon,
Assuming you have XP, right mouse on My Computer in the Start Menu and select Properties. Then click the Advanced Tab. Under the Performance section click Settings. Click Advanced. In the Virtual Memory section there is a sentence "Total Paging File size for all drives: XXXX.
What is the number XXXX?
John
BTW, you should also have DMA enabled for your hard drives and Write Caching should be disabled. This is described in Appendix D of the User manual. (P189)
