how do I create an initial Menu at start of slideshow?
photon
Post by photon »
Ok.. admitedly I'm not the best at following instructions in a manual !
I want to create a Slideshow, - 2 groups of photos, not a problem so far..
but how exactly do I place a Menu at the start to start either slideshows?
step by step would be nice - :) sorry... just still getting used to this, and I know it should be simple - it IS a great program - just this one point has me struggling. :?
thanks.
It seems that you haven't pressed the "Next" button to proceed. The program will build the menus. In this first screenshot we have 2 "Titles", or Slideshows. You would stay in this Step until you have completed adding slideshows or video clips. You then press the Next button located at the lower right.
This takes you to the 2nd Step, which is constructing your DVD menus. On the left are the Templates used to build these menus. There is a drop-down arrow at the top where you can access all the different styles of menus. There should be Smartscene, Text-Only, Thumbnail, and Favorites. Note: you will not have anything under the Favorites category, unless you add them.
Then at the top you can click on the Edit Tab to access it. Here you have numerous options to customize your Menus.
You might also want to have a look at Steve's tutorial on Authoring a DVD, which is just a part of the total tutorial, From Camcorder to DVD with VS. The authoring of a DVD in VS is much the same as that in MovieFactory.
photon
Post by photon »
Many thanks for that, very much appreciated,
and very clear / understandable,
greatly appreciated,
Stu'
