Windows Media Player Plays NTSC Incorrectly
ccoty
Post by ccoty »
I've just installed v9.0 (and uninstalled v8.0) and created a DVD compliant Mpeg (4:3). The mpeg creates properly and then when I attempt to open the created file, Windows Media Player v10.0 does not interpret the size properly. For some reason it thinks I've created a 720x576 instead of the 720x480. It shows a squat version (not full screen) and when I click on properties while in Windows Media Player it shows 720x576.
Other players such as ATI & PowerDVD interpret the dimensions correctly at 720x480 & play the created mpeg full screen (4:3)
Anyone know if there is a codec issue? I've never had the problem in the past with VS v8.0.
When I look at the properties of the created mpeg in Video Studio it show the file to be a 720x480 but in Windows Media Player 10 it shows a 720x576, which is the size of PAL not NTSC.
Thanks for any light you can shed on this.
Chuck
jchunter
Post by jchunter »
Chuck,
I noticed the same thing in WMP9, so I upgraded to 10 and the same thing happened. There is an aspect ratio problem with the video files that I have made with VS9 - and, I just checked, VS8, as well. 4:3 videos are played back at an 8:5 aspect ratio. I don't know which company is at fault, but until someone fixes the problem, PowerDVD works very well for checking video file playback.
John
Edit: I did not notice this problem before I installed VS9 and am now wondering if Ulead updated a .dll that WMP uses....
THoff
Post by THoff »
Download the Windows XP Video Decoder Checkup Utility, and check which of the installed DVD decoders is being used by WMP, and select a different one if needed.
