"Unable to finish the GIF Optimiztion process."
GIF Animator, SmartSaver Pro, Plugins, Applets....
MrBucket
Post by MrBucket »
Sorry to make a new topic on this, but I need help. Same problem as some only I don't have vista or anything like that.
Screen shot can be found here.
http://i29.photobucket.com/albums/c258/ ... 1/help.jpg
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
How many frames do you have there? Looks like a few... you may have too many frames. You could try removing any frames that are the essentially the same image as the one before.
Can't really see that screen shot too well. Kinda small and fuzzy... do I see two frames numbered "2" in there and no 3?
Have you tried closing the color palette box when optimizing? Tried clicking "Preview" tab and skipping the "Optimization?"
Completing your system information may be helpful, too.
MrBucket
Post by MrBucket »
I tried another one with just 8 frames and I get the same error.
Sorry for the fuzzy screen, I didn't know photobucket shrinked it.
Also the Color Palette box comes up when I optimize, if I try to click on the Preview tab then I get the error, "Generating the HTML code failed. Unable to finish..."
System info
Intel Q6600 quad core
2gb ram
8600 GT
160gb hard drive
Windows XP Home
VikingAnimations
ram: 4 GB
Hmmm...
Is Windows' Data Execution Prevention turned on for all programs?
Right-click your MyComputer icon and select Properties. Go to the Advanced tab. Under Performance, click the Settings button, and on the box that pops up, the Data Execution Prevention tab. What's it set for?
MrBucket
Post by MrBucket »
It was set to just essential windows programs, I set it to all programs except the ones I select and still no luck.
Also if I just preview I get a "Generating HTML code failed."
VikingAnimations
ram: 4 GB
I'm pretty much at a loss here. About all I can think of, based on what info I have, is to try running GA 5 in another compatibility mode...
Right-click the shortcut to GA 5, select Properties. Try setting the compatibility to Win 2000.
My only thought is the quad-core chip? The only time I've seen that error is when optimizing a massively big animation.
Can you optimize any other animations, or is the problem limited to this file?
MrBucket
Post by MrBucket »
I have tried with a small 8 frame GIF that was already made and no luck. I also just tried opening a JPeg image and still it would not optimize.
I changed the compatability to Windows 2000 and now when I try to open an image it just crashes on me.
I will try to install on another system I have without the quad core and see if it works.
VikingAnimations
ram: 4 GB
I hope the other system likes it! I'm rather curious as to the cause of that issue...
Keep us updated!
