Transition
Transition
Can anybody advise if there is a way to simulate a camera flash in a transition - Thanks
In Charlie Hills' book, Getting Results with VideoStudio, he actually had a tutorial for this. It centered around using a white color block - only a frame or two. I'm sure somebody that still has the book will chime in with the exact details.
Jeff
Dentler's Dog Training, LLC
To create a camera flash according to Charlie Hill...
Credit goes to Charlie Hill, and his Getting Results with VideoStudio 9 book. , which you can purchase and learn a lot more. Now hopefully he won't sue me for violating copyrights...
http://www.getting-results.com/
- You will of course have 2 video or image clips in the time-line.
- Place 2 White color clips between them. So the sequence would be Video Clip, White Color Clip, White Color Clip, Video Clip.
- Now drop 1 Fade to White Transition between the First Video Clip and the First Color Clip. Then drop a second Fade to White Transition between the 2nd Color Clip and the 2nd Video Clip.
- In StoryBoard mode, highlight the 1st Transition, and change the duration to 2Frames, not seconds.
- Now highlight the 1st White Color Clip, and change the duration to 2 Frames.
- Next go to and highlight the 2nd Fade to White Transition, and change the duration to 6 Frames.
- Now change the 2nd White Color Clips duration to 6 Frames.
Yes most of the information would be. Just treat VS11 as having only 1 overlay track. Charlie covers far more than just the mechanics of doing things. He gets you to "think outside the box", and explains a lot about video editing itself.
He also wrote one called Getting Results with MediaStudio Pro 8, which I also own.
I knew someone would come thru. Thanks Ron.
Jeff
