Problem Rendering MPG-2 File for DVD
toddyboy
Post by toddyboy »
Greetings... I'm just starting with VS 11 plus and the first project that I'm testing to try to burn to DVD is resulting in a DVD video with ok sound, but the video comes out looking like a bunch of moving colored waves, kind of like a TV picture that you can't see because there's no antenna, if you can imagine that.
The file is a short MPG-2 that looks/plays fine when I add it to the timeline in VS. When I go through the process of creating a DVD (either burn to DVD or make a DVD folder on the computer hard drive), the program indicates that it was successfully created, but when I play it with Windows MP, it looks all garbled. I tried turning smart rendering off, which made no difference. I also used the step by step process described on this forum
I haven't tried any other file formats yet, as I will be starting with MPEG-2 files from the camcorder that I am planning to get. I've done a fair amount of editing before with some other programs, but know little about VS.
Can you folks guide me through a troubleshooting sequence, or better yet, tell me how to fix this? Very frustrating and I'm hoping it's something simple. Thanks for any help - Tod :?
System - Pentium IV, 1.8ghz, 1.2mb ram
Devil
Post by Devil »
Try reading the READ ME FIRST BEFORE YOU POST and comply with the instructions. That way, we may learn a little of your settings and other essential info.
Post by Black Lab »
What are your clip properties (from the library or timeline right click on one)?
What are your project properties (File>Project Properties)?
What are your output properties (from the burn window [Share>Create Disc] click on the gear icon in the lower left)?
toddyboy
Post by toddyboy »
Here are the properties. Let me know if there's other useful info I can provide. Thanks again for any help - Tod
clip properties
File format: NTSC DVD
File size: 32 544 KB
Duration : 35 369 seconds
Video type : MPEG -2Video ,Lower Field First
Total frames : 1 060 frame s )
Attributes: 24 bits,720 x480 ,4:3
Frame rate : 29 970 frames /sec
Data rate : Variable bit rateMax . 8000 kbps )
project properties
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
output properties
MPEG files
Lower Field First
(DVD-NTSC), 4:3
Audio data rate: 256 kbps
toddyboy
Post by toddyboy »
Properties above...
Post by Black Lab »
Hmmm. All your properties look right on. You say you see the problem in WMP. Did you actually burn to disc and play it from a DVD player?
toddyboy
Post by toddyboy »
Jeff
Duhhh... I should have known better than to trust WMP - I hadn't tried it in a DVD player, and now I see, yes it does work. Just installed WinDVD and it works there too on the computer. What's up with media player - I've played plenty of commercial DVDs with it. Anyway, thanks for saving me a ton of time and grief - Really glad to find this forum - Tod
Post by Black Lab »
Even a blind squirrel finds a nut once in a while. :wink:
sherman39
motherboard: HP 894B 10
processor: Intei I7-12700
ram: 16gb
Video Card: Nvidia RTX 3060 12GB
Hard_Drive_Capacity: 500GB+1TB
Corel programs: Video Studio
Post by sherman39 »
and you know that how?
CycleWriter
Post by CycleWriter »
sherman39 wrote:and you know that how?
Just a guess, but judging from what I've seen of him in here for the past year and a half, he's pretty squirrely. :lol: :wink:
Post by Black Lab »
I resemble that remark. Yuk yuk yuk. :D
