I have tried everything. I am making a dvd file with jpg files. I took them on a sony 8.0 megapixel camera. Everytime I put them in the timeline they all look distroted. I have tried everything. I tried changing the resolutions. I switvhed it from 16x9 to 4x3. Flciker on then off and everyhting else. If I change the reseoltion to 1024x682 it looks a little better but when I make the screen bigger it gets distorted. Somebody please tell me what I am doing something wrong.
Thanks.
Distorted pictures with a 8.0 megapixel camera?
Moving Path
When importing an image, there's a little checkbox in the lower left corner that says "keep original size with moving path automatically' -- make sure you check that box...
George
I just tried that and it looks better but it zooms in 5 times the picture size. I tried reducing it to 1024 x 682 but it still zoomed in. What would I resize it to for a 16 x 9 project. I don't want it to be distorted on a big screen with a small file size. Thanks for your help. I think I'm getting closer.
Terry Stetler
Overlaying a large picture in a 720x480/576 video frame will make it spill over the edges. You could just resize it using an imaging program to something more appropriate.
Alternatively, and presuming you want to keep its detail in order to effectively zoom in on a portion of it at some point in the project, use the Width/Height controls in the 2D Moving Path dialog to zoom out on the full image.
Terry Stetler
Terry Stetler
Obviously you can't resize it in an image editor and maintain the same quality, but you also have to take into account the display device and if it can actually show that high a quality. A TV cannot, even an HD one.
Also: if you're going to resize an image to fit the visible portion of the video frame a size of 640 wide is more appropriate because much of the typical 720 wide frame is invisible on a TV, laying outside of what's called the "title safe margin".
Perhaps the best option for you is to load in the full sised image and use a moving path to scale it to fit the visible portion of the video frame.
At least that way if you at some point have to zoom in on the image the quality won't suffer as much.
Terry Stetler
