VideoStudio 11+ w/updates
Cable Tuner: Motorola DCT6416
Capture: Plextor ConvertX M402U
Trying to capture video from CATV source using S-video hook-up (from tuner). This same hookup works with other software. In VS11 when I click the first Capture Video button, video plays in preview window. When I click the second Capture Video button to begin capture, entire computer freezes. Cursor barely moves and I must use Ctrl Alt Del to get the Task Mgr screen to exit. Plenty of hard disk space. Any thoughts?
TV Capture Crash
I found a nifty free program called Process Explorer at http://technet.microsoft.com/en-us/sysi ... 96653.aspx that details all the processes running on my PC. By saying you have a profile, does that mean you have a method that closes all the processes you won't be using with one stroke when you get ready to start video editing? If so, how does one set that up?
Ok, I just tried stopping some of the larger processes I wasn't using. I still had about 44 processes running, most very small. My CPU usage under the Performance tab of Task Manager was running between 0 & 2%. When I opened VS and then clicked on the Capture Video button, the CPU Usage shot up to 100% and stayed there. That can't be correct.........right?
Steve (sjj1805) wrote a tutorial called Creating a Video Editing Profile, where he explains everything about how to go about creating one.
That is not uncommon for the CPU to run at 100% when capturing. That should demonstrate just how demanding it is on your PC.
If you don't want to create a video editing hardware profile there is a small free program called EnditAll2, that allows you to safely stop processes that is not needed. You can download it from the following link:
http://www.docsdownloads.com/Tier1/enditall.htm
Okay, I've been working on this all day. I followed the directions in the Video Editing Profile tutorial. Results:
Before:
Processes: 50 CPU Usage: 0 - 2% PF Usage: 351mb
After:
Processes: 17 CPU Usage: 0% PF Usage: 114mb
By the way, I have 1gb memory. As before, everything comes to an abrupt halt when I click on the Capture Video button. I though it was because I was attempting to capture a program in HD but when I switched to a non-HD channel, same thing happened. VS completely stops responding. Any other ideas?
Before:
After:
