Theme template removal from movie wizard
stringbeing
Post by stringbeing »
HI, how do I remove theme templates from the movie wizard? I don't want themin my videos!
If you're using the movie wizard, you will have to choose one of the templates. If you don't want to use the themes, then don't use the movie wizard.
woodchuck
motherboard: PEGATRON Corporation 2AC31.04
processor: 2.80 gigahertz Intel Core i7-2600S
ram: 8.2 gb
Video Card: AMD Radeon HD 6550A
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 Tb
Monitor/Display Make & Model: Generic PnP Monitor
Post by woodchuck »
Stringbeing,
When you get back to the editing phase, after using the Movie Wizard, you can delete the theme clips. You will need to make sure the timeline is in "timeline view" not "storyboard view" so you can see the overlay clips. You will probably want to go to the end and delete the theme there are well.
This feature can be annoying especially when you don't add all the clips at once. When you return to the Wizard to add more clips to your project, it will add the theme at the end of your project. Then you have to remove it again. In my opinion, there should be a way to select "no theme".
There is a way, it's called the Editor. The Movie Wizard was designed so that themes or rather templates could be used to produce interesting and more professional videos, without having to manually do this.
The Editor allows for tweaking what the Wizard produces, or for complete control over your editing. The Wizard without adding or using the themes is nothing more than using the editor to add your clips.
Sorry it just makes no sense to me, to use the Movie Wizard if all you're doing is adding clips, or images without the themes...;)
stringbeing
I did see that option last night under the Editor mode, I'll use that...thanks!
