DVD won't play on set top DVD player.
wstagner
motherboard: Gigabyte Ga-p43-es3g
processor: Intel Core 2 Quad Q8400 2.66 GHz
ram: 8gb
Video Card: ATI Radion HD4300 4500 series
sound_card: ATI High Definition Realtek ALC888 codec
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Asus VH242H 24" 1920x1024 screen.
Post by wstagner »
Can any 1 point me to a thread for this subject?
I've searched for DVD won't play in set top box, DVD won't play, etc. and I get thousands of hits on a search.
I have Video Studio 10+ and the first DVD I burned with all the defaults played in my Philips DVD player just fine. I then changed the default sound clip and nothing else to my knowledge. I've since created 10 other DVDs of the same clip. They all play on my Sony DVD burner just fine.
I've no problem playing commercial DVD or DVD made by other people on my Philips. What can possibly be wrong? I'm using Imation DVD+R blanks and the software tells me it's burning at 3x.
Anyone have any ideas or if this info is in another thread, please move this post to that thread and direct me to it.
Thanks,
Walt
DVDDoug
Moderator
Post by DVDDoug »
Were these also made with DVD+R blanks? You might try a DVD-R...
You might also try making a copy of one of your previous working discs. If the copy doesn't play, then your player (or burner) is having trouble with this batch of discs.
If none of the above helps, tell us what file formats you are using and where the files came from. ...File format-conversion problems are common, but usually Video Studio will warn you (or fail) before the actual DVD gets burned.
From what you've told us, I doubt there is a physical problem with the DVD or the "burn". (I suspect it's a data problem). But just to make sure, Nero CD-DVD Speed (FREE!!!) can usually tell you if you have a physical problem. Another quick-test is to drag the VIDEO_TS folder to a temporary folder on your hard drive. If you get an error, the drive is having trouble reading the data. (The player-software can correct or hide some errors... The fact that a DVD plays, does not mean all of the data is getting read correctly.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
wstagner
ram: 8gb
Post by wstagner »
Thanks for the quick reply. File is a 19 minute video file captured from my mini DV camcorder. I'll check that other thread too.
wstagner
ram: 8gb
Post by wstagner »
Another piece of info....after the screen says LOADING, it then displays MP3-JPEG and starts counting down a bunch of numbers, as if it's going to load up a bunch of mp3 files or jpegs.
VERY odd.
Please view the following links:
Please read this before posting
and
Suggested workflow by sjj1805
Please click here --> Image so that we can then view your system specifications.
