Hello.
I am sure that I have managed this before without problems but can't manage to work it out this time.
I've got a 120 minute video rendered to mpg at abou 9100 kbps. I would like to reduce the bitrate so that I can fit it onto a single layer DVD so I used UVS10+ to convert to 6500kbps. Unfortunately the resulting video is jerky, stuttering all the way through (audio is fine but goes out of sync). I retained all other details, making sure field order was fine etc.
It's a simple thing to do and I'm sure I've done it successfully before - can anyone advise what might be going wrong this time?
Thanks,
Stewart.
Jerky playback when I compress mpeg
StewartTurner
http://www.deepset.co.uk
Hi Stewart
I assume the quality of the original is ok.
I would also assume that the settings have changed after render., Probably the field order?
I would use the Make Movie Manager to create a template.
Use the Add function and select your original file as the ¡¥file path¡¦
Then edit the template changing only the Bit rate to 6000kbps
Now start a new project, insert the original video clip
Share Create Video File ¡V selecting your template.
You will now render using the same settings except for the bit rate.
I have some notes here on Movie Manager
http://uk.geocities.com/trevor.andrew@b ... anager.htm
An alternative approach you might consider would be to produce DVD folders from the 9100kbps mpeg2 file, and then use DVD Shrink to make them fit a single layer DVD.
Some posters claim this results in a better quality final DVD than you would get from re-encoding to a lower bitrate in VS. I've been meaning to do some tests to check this out myself.
StewartTurner
