Titles not centered when using DVD wizard
jeffy
Post by jeffy »
When I use the create disc wizard to create dvd folders, the titles in my project are not centered properly (they appear off to the right of center). If I create a video file of the same project, with dvd option, the titles are centered. The project was created with vs7, and I just upgraded to vs11 and worked the project file to fix things like adding chapters etc. I even deleted my titles and re-entered them, using the multi title function, then using the alignment button to center them.
anyone have/ deal with this?
Welcome to the forums,
First if you're going to use a project file from an older version, Save the project file with a new name in VS11. If you don't it will over-right the VS7 VSP, and you will no longer be able to open it with VS7 if need be.
Next it seems that you're going straight to the burn module, instead of following the
Recommened WorkFlow for VideoStudio. While your workflow is possible, if it fails, then try the above.
Please read this post, and return with as much of the information as possible.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
We don't know if you're using 16:9 or 4:3 aspect ratio, or anything about the source video files, which may play a part in why your titles are getting thrown off center..
jeffy
Post by jeffy »
I know that now!
anyway, I just deleted the titles (only had 15 or so) and then re-did them with vs 11, they turned out great!
I'll read the workflow and see if i'm doing things the way suggested.
Thanks again.
