Each time I try importing DVD content in MF6Plus by flagging one or more chapters the system hangs a while and throws this error:
Code: Select all
Unspecified error
report ID 0x80041460(5216)Code: Select all
fail to get DVD disk stream reader
report ID 0x80040911(2321)I'm not sure but I have the feeling this did not happen with the demo version I downloaded and installed before purchasing the full version of the program....
Project settings are:
Code: Select all
MPEG files
24 bits, 352 x 576, 25 fps
Frame-based
(DVD-PAL), 16:9
Video data rate: Variable (Max. 2500 kbps)
Audio data rate: 224 kbps
Output format DVD (4,7 GB) PALCode: Select all
c:\windows\system32\imaadp32.acm Microsoft Corporation IMA ADPCM Audio CODEC OK C:\WINDOWS\system32\IMAADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 16,00 KB (16.384 Byte) 08/04/2003 14.00
c:\windows\system32\ivimp3en.acm Intervideo Inc. Intervideo MP3 Audio CODEC OK C:\WINDOWS\system32\IVIMP3EN.ACM 1.2.0 331,50 KB (339.456 Byte) 09/03/2007 11.20
c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\WINDOWS\system32\L3CODECA.ACM 1, 9, 0, 0305 284,00 KB (290.816 Byte) 08/04/2003 14.00
c:\windows\system32\msadp32.acm Microsoft Corporation Microsoft ADPCM Audio CODEC OK C:\WINDOWS\system32\MSADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 14,50 KB (14.848 Byte) 08/04/2003 14.00
c:\windows\system32\msg711.acm Microsoft Corporation Microsoft CCITT G.711 Audio CODEC OK C:\WINDOWS\system32\MSG711.ACM 5.1.2600.0 (xpclient.010817-1148) 9,00 KB (9.216 Byte) 08/04/2003 14.00
c:\windows\system32\msg723.acm Microsoft Corporation msg723.acm OK C:\WINDOWS\system32\MSG723.ACM 4.4.3400 116,00 KB (118.784 Byte) 25/02/2006 13.13
c:\windows\system32\msgsm32.acm Microsoft Corporation Microsoft GSM 6.10 Audio CODEC OK C:\WINDOWS\system32\MSGSM32.ACM 5.1.2600.0 (xpclient.010817-1148) 19,50 KB (19.968 Byte) 08/04/2003 14.00
c:\windows\system32\sirenacm.dll Microsoft Corporation Messenger Audio Codec OK C:\WINDOWS\system32\SIRENACM.DLL 8.5.1302.1018 50,02 KB (51.224 Byte) 18/10/2007 12.31
c:\windows\system32\sl_anet.acm Sipro Lab Telecom Inc. Sipro Lab Telecom Audio Codec OK C:\WINDOWS\system32\SL_ANET.ACM 3.02 84,00 KB (86.016 Byte) 08/04/2003 14.00
c:\windows\system32\tssoft32.acm DSP GROUP, INC. DSP Group TrueSpeech(TM) Audio CODEC OK C:\WINDOWS\system32\TSSOFT32.ACM 1.01 8,00 KB (8.192 Byte) 08/04/2003 14.00
c:\windows\system32\vct3216.acm Voxware, Inc. Voxware Compression Toolkit OK C:\WINDOWS\system32\VCT3216.ACM 1.6.0.17 81,00 KB (82.944 Byte) 02/03/2001 19.46c:\windows\system32\divx.dll DivX, Inc. DivX 6.8.0 Codec OK C:\WINDOWS\system32\DIVX.DLL 6.8.0.14 666,50 KB (682.496 Byte) 21/02/2008 3.04
c:\windows\system32\huffyuv.dll Disappearing Inc. Huffyuv lossless codec [HFYU] OK C:\WINDOWS\system32\HUFFYUV.DLL 2.1.1 - CCESP Patch v0.2.2 38,00 KB (38.912 Byte) 08/12/2001 21.20
c:\windows\system32\iccvid.dll Radius Inc. Cinepak Codec by Radius Inc. OK C:\WINDOWS\system32\ICCVID.DLL 1.10.0.11 78,50 KB (80.384 Byte) 08/04/2003 14.00
c:\windows\system32\ir32_32.dll Intel(R) Corporation Indeo codec by Intel OK C:\WINDOWS\system32\IR32_32.DLL Non disponibile 194,50 KB (199.168 Byte) 08/04/2003 14.00
c:\windows\system32\iyuv_32.dll Microsoft Corporation iyuv_32.dll OK C:\WINDOWS\system32\IYUV_32.DLL 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 46,50 KB (47.616 Byte) 31/08/2001 1.07
c:\windows\system32\lvcodec2.dll Logitech Inc. OK C:\WINDOWS\system32\LVCODEC2.DLL 11.5.0.1145 406,52 KB (416.280 Byte) 27/01/2007 9.44
c:\windows\system32\msh261.drv Microsoft Corporation msh261 OK C:\WINDOWS\system32\MSH261.DRV 5.1.2600.2180 188,00 KB (192.512 Byte) 25/02/2006 13.12
c:\windows\system32\msh263.drv Microsoft Corporation msh263 OK C:\WINDOWS\system32\MSH263.DRV 5.1.2600.2180 292,00 KB (299.008 Byte) 09/09/2002 15.51
c:\windows\system32\msrle32.dll Microsoft Corporation Microsoft RLE Codec OK C:\WINDOWS\system32\MSRLE32.DLL 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 11,00 KB (11.264 Byte) 08/04/2003 14.00
c:\windows\system32\msvidc32.dll Microsoft Corporation Microsoft Video 1 OK C:\WINDOWS\system32\MSVIDC32.DLL 5.1.2600.0 (xpclient.010817-1148) 25,00 KB (25.600 Byte) 08/04/2003 14.00
c:\windows\system32\msyuv.dll Microsoft Corporation msyuv.dll OK C:\WINDOWS\system32\MSYUV.DLL 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158) 17,00 KB (17.408 Byte) 31/08/2001 1.07
c:\windows\system32\tsbyuv.dll Microsoft Corporation tsbyuv.dll OK C:\WINDOWS\system32\TSBYUV.DLL 5.1.2600.0 (XPClient.010817-1148) 8,00 KB (8.192 Byte) 31/08/2001 1.08
c:\windows\system32\xvidvfw.dll Non disponibile XviD MPEG-4 Video Codec OK C:\WINDOWS\system32\XVIDVFW.DLL XviD 152,00 KB (155.648 Byte) 20/12/2004 11.08
