How do I uninstall Ulead DVD Movie Factory 3.5 SE?
I tried MS Add/Remove programs. I get a cryptic error message such as:
>SetupDLL\ SetupDLL.cpp(439)
paPP:Ulead DVD MovieFactory 3.5 Suite Deluxe
PVENDOR: Ulead Systems
PGUID: C7D89BBE-d4b3-49e8-b185-7966b5345866
$7.1.100.1248
@Windows Me (73010104) IE 6.0.2800.1106
OK
I click OK, then I get another message :
- Close any running programs
- Empty your temporary folder
- - Check your Internet connection
Doing the above does not fix anything. I get the same error messages again.
Note that MS Add/Remove programs currently works perfectly to uninstall other programs.
Any help appreciated.
FredJ
jcc
The following was submitted on another thread earlier this month by rrobbins611. It refers to removing 4.0 but may help with your 3.5.
I sent an e-mail to tech support an received the following recommendation to completely remove MovieFatory 4.0 and reinstall:
Perform a Clean Remove of the program from your system. You may or may not find all entries in the list.
1. Launch Windows Explorer and go to
"Tools > Folder Options > View" to check "show hidden files and folders".
2. Please purge/delete all the files in these folders:
"C:\Windows\Temp"
“C:\Documents and Settings\[User Name]\Local Settings\Temp” (for WinXP and 2000)
"My Documents\Ulead DVD MovieFactory\4.0" (Working Folder)
3. Go to "C:\Program Files\Ulead Systems"
4. Delete the folder for MovieFactory 4.0
5. Delete "C:\Program Files\Common Files\Ulead Systems". If a file says it cannot be deleted, open the Task Manager and end the process named "ulcdrsvr.exe" then delete the folder again.
6. Go to "C:\Program Files\InstallShield Installation Information"
7. Delete the folder "{448AB2CB-C94A-47DE-80B8-9D7824DEFA57}"
8. Go to Start-->Run
9. type "regedit"
10. Go to
"HKEY_CURRENT_USER\Software\Ulead Systems\Ulead DVD MovieFactory"
and
"HKEY_CURRENT_USER\Software\Ulead Systems\Ulead DMF"
11. Delete the folder "4.0" for both locations.
12. Go to
"HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Ulead DVD MovieFactory"
and
"HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Ulead DMF"
13. Delete the folder "4.0" for both locations.
14.Close "Regedit"
15.Restart Windows
16.Reinstall MovieFactory 4
"C:\Windows\Temp"
9. type "regedit"
10. Go to
and
12. Go to
and
14.Close "Regedit"
15.Restart Windows
FredJ
jcc
FredJ
Masami
FredJ
You are right. Here is what setup.ini says for this file (which shows that it was the correct one for DMF 3.5):
[Startup]
EnableLangDlg=Y
AppName=Ulead DVD MovieFactory 3.5 Suite Deluxe
ProductGUID=C7D89BBE-D4B3-49E8-B185-7966B5345866
CompanyName=Ulead Systems
ErrorReportURL=http://www.installshield.com/isetup/Pro ... rorCode=%d : 0x%x&ErrorInfo=%s
MediaFormat=1
LogMode=1
Resource=_Setup.dll
SmallProgress=Y
SplashTime=5
CheckMD5=Y
CmdLine=
ShowPasswordDialog=N
Engine=0
Source=0
AllUsers=1
InstallGuid={C7D89BBE-D4B3-49E8-B185-7966B5345866}
[Languages]
Default=0x0009
count=3
key0=0x0009
key1=0x040c
key2=0x000a
Fredj
[Startup]
EnableLangDlg=Y
MediaFormat=1
LogMode=1
Resource=_Setup.dll
SmallProgress=Y
SplashTime=5
CheckMD5=Y
CmdLine=
Engine=0
Source=0
AllUsers=1
[Languages]
Default=0x0009
count=3
key0=0x0009
key1=0x040c
key2=0x000a
Fredj
