Video Filter
vman1949
Video Filter
Post by vman1949 »
I am using VS 11+ in trial mode to evaluate the product. I used a photo and applied the 'bubbles' video filter to it and it looked great, with the bubbles moving across the photo. However, when I apply the same filter to a video clip, the bubbles appear, but they are not moving, just static. I was wondering if this is what happens, or if I have missed something.
Post by Trevor Andrew »
The speed of the video filter appears to be related to the length of the clip it is applied to.
How long is the image clip?
How long is the video clip?
Use the scissors to cut the video into shorter segmants, the effect should speed up.
vman1949
Post by vman1949 »
The image is 6 seconds the clip 1 minute. So is this a software a limitation or a limitation of my computer?
I shortened the clip to 10 seconds and the bubbles move but now the audio is crappy and clip is jerky. Can't win.
Firstly don't go by what you see on the preview screen.
Render out a short sample video to see the finished effect.
Secondly remember that the bubble filter is customizable.
vman1949
Post by vman1949 »
I knew the filter is customizable and was using less values than the ones you showed in your screen capture. The tip about rendering made my day! It is tricky to synchronize the filter with the jerky video in the preview screen.
Post by Black Lab »
Even in the preview screen it shouldn't be jerky. What kind of clips are you dealing with? What are your project settings?
vman1949
Post by vman1949 »
Clip is a section of 12 minute video captured from analog camcorder set at
DVD NTSC AC3HQ template. The clip itself is 1.5 minutes long. Project properties are 24 bits 720x480 29.9 fps Upper field first (DVD-NTSC) 4:3
Hope this helps.
Post by Black Lab »
Right click on a clip and post all the properties.
Go to File>Project Properties and post all the properties.
vman1949
Post by vman1949 »
Clip properties:
File Name UVS080303-006.mpg
File Format NTSCDVD
FIle Size 724,824 KB
Duration 732.332 seconds
Video type MPEG-2 VIdeo, Upper Field First
Total frames 21,948 frame(s)
Attributes 24 bits, 720 x 480, 4:3
Frame rate 29.970 frames/sec
Data Rate Variable bit rate (Max 9000 kbps)
Audio type Dolby Digital Audio
Total Samples 35,151,952 samples
Attributes 48000 Hz
Layer None
Bit rate 384 kbps
Project Properties
File size 0 bytes Version 11 Duation 00:01:43.16
Edit file format Mpeg files
Ntsc drop frame 929.97 fps)
MPEG Files
24 bits, 720 x 480, 29.97 fps
Upper field first
(DVD-NTSC), 4:3
Video data rate Varible (Max 9000kbps)
Audio data rate 384 kbps
Would more memory help this problem?
