poor picture quality
After I have added video to my computer from my mini dv camcorder, the picture quality seems very poor and even worse when I put it to full screen. Is there something I can adjust to fix that will help? I'm using Video Studio 9 SE
Please read and comply with the PLEASE READ THIS BEFORE POSTING thread. Then tell us EXACTLY what you are doing, where your video source is, the VS settings/properties, the MPEG-2 settings, the project size etc. We cannot guess what you are doing.
Properties of your source files (format, file size, where did you get it?):Format is microsoft AVI files--opendml, file size is 10,233 Kbytes, DV camera
What devices are involved and their mode of connection?: Mini DV camcorder
Project Properties (important):
MPEG Files:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
Output format (file, DVD, VCD, SVCD):
Microsoft AVI files:
Microsoft AVI files
24 Bits, 320 x 240, 30 fps
Lower Field First
Uncompressed
PCM, 44.100 kHz, 16 Bit, Stereo
PAL or NTSC:NTSC
Error Codes (if any):NONE
Product Version:VS 9 SE DVD
Hopefully this is what you guys need.
MPEG Files:
MPEG files
Lower Field First
(DVD-NTSC), 4:3
Microsoft AVI files
Lower Field First
Uncompressed
PAL or NTSC:NTSC
For full quality you should capture your Mini ¡VDv via firewire.
In the capture window you should select DV as the format, also select Type 1 from the ¡¥options¡¦ cogwheel.
This will transfer your footage to the pc using Dv-Avi
These files are about 13 Gb per hour.
Your frame size should be 720 x 480
See my quick Guide to Avi from the link below.
AND, your clips are dv-avi, but your project is set for MPEG-2. Make sure your project settings match your clip settings.
Jeff
Dentler's Dog Training, LLC
Jeff
select DV as the capture format.breeder44 wrote:Bill??? I used a firewire to capture. How do I change it from MPEG to DV- Avi?
Then Type 1 from Options cogwheel
If you see a Avi option, that should revert to DV, as you are connected to a Digital device.
See my quick Guide to DV-Avi from the link below
