Hi Guys
Have just upgraded to the DMF 6Plus the other day, after installing the program (which during the install had a number of birthdays and became the legal age for the pension) noticed the patches, my question is do I need to install the patches as well.
DMF6 Plus Install
Budda_357
- motherboard: Gigabyte GA-Z68XP-UD4 V1.3
- processor: I7-2600K OC 4.6 Ghz
- Video Card: Asus GTX660Ti 2GB OC Edition
- sound_card: On Board 7.1 HD Audio
- Hard_Drive_Capacity: 11.240 TB
- Monitor/Display Make & Model: Samsung S23A950 23in 120Hz 3D Widescreen LED Monit
DMF6 Plus Install
Cheers From Down Under
Budda [sic]
DVD Movie Factory: DMF4SE, V5 Plus, V6 Plus, V7 Pro
Video Studio: V10, V11.5, VX2, VX4, VX5, VX7 (Ultimate Versions)
Photo Impact: VX3
Paint Shop Pro: PSPX3, PSPX5, PSPX7 (Ultimate Versions)
Painter Essentials: V3, V4
Budda [sic]
Photo Impact: VX3
With MF6+, Patch#2 is a critical update. You need to install it. Patch#2 fixes many problems.
Also make sure to download and install the latest version of "Direct X 9.0C dated Novermber 2007"
http://www.ulead.com/tech/dmf/dmf.htm
Budda_357
Thanks Guys
I also installed PI X3 which ran a direct X update. Is Direct X V4.09.000.0904 the Nov 07 Update
Budda [sic]
Photo Impact: VX3
Budda [sic]
Photo Impact: VX3
Budda_357
Thanks for that.
I did an exercise with the other computer, it had the same version then I ran the November Direct X udate.exe. It ran through the the usual and said will check your files and update and so on, during the process of checking the files it said it was copying new files? after it completed its job checked to see the version and no change then checked the files and it had copied or replaced 17 files
Here is a list of the files that were updated
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 3/7/2008 10:39:23 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 3/7/2008 10:35:07 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 3/7/2008 10:35:28 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 3/7/2008 10:35:44 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 3/7/2008 10:36:00 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 3/7/2008 10:36:16 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 3/7/2008 10:36:36 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 3/7/2008 10:36:57 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 3/7/2008 10:37:13 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 3/7/2008 10:37:30 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 3/7/2008 10:39:28 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:32 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:36 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:41 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:45 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:15 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 3/7/2008 10:39:19 12800 bytes
So does this mean it does not matter what the version says it is for OS XP?
But find the latest update and run it.
Now will check the computer when I get home that installed PI X3 and see if it copied the same files.
Budda [sic]
Photo Impact: VX3
Budda [sic]
Photo Impact: VX3
