Ripple Editing in VS-11
jaeger1952
Post by jaeger1952 »
Can someone explain what Ripple Editing is and how it can be used? Is there a tutorial somewhere?
Post by Black Lab »
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Ripple Editing
Post by Ken Veal »
Bob Hughes
motherboard: Dell Inc. 0Y2MRG A01
processor: 3.40 gigahertz Intel Core i7-2600
Hard_Drive_Capacity: 1.5 TB
Post by Bob Hughes »
The important thing to remember about ripple editing is that everything that is ripple enabled will be effected. On my slide shows I sometimes have to temporarily move a title so it won¡¦t be deleted. I also don¡¦t enable the music track ripple because it stretches across many slides. You have to think about which tracks you want controlled at the time of editing.
Bob
Ken Veal
ram: 32 GB
Title ripple edit
Post by Ken Veal »
Bob,Can you advise me when you have had a title deleted through using RE-did not think this could happen..............Ken
Bob Hughes
If you delete an image and there is a title overlapping the same time frame it will also be deleted Although the system does warn you before doing it. That is why I move title aside first & then reposition after delete.
Bob
jaeger1952
Ken, Jeff, Bob!
Thanks for the quick response. Answered my question perfectly.
Now, for a followup question....
I want to insert a transition [fade to black effect], followed by black background screen [color]---into the middle of my photo slide show project---onto which I want to add some lengthy text over the black background. I've got Ripple Editing turned on for all elements and have tried to add the "fade to black" transition effect between clips, but I keep getting a message stating that the transition effect is too long and that it will be automatically shortened (even though I have not specified a length for the transition effect...yet!)
I've even tried highlighting all the subsequent clips from the point where I want to insert the transition in hopes that I could slide them all further along down the time line as a group, thereby hoping to create a space for my transition effect and background color onto which to apply text. No dice! Video Studio 11 won't let me do that.
Is there any way of making this work?
I've put so many hours into this project that I'm terribly afraid of messing it up and having to start from scratch! I've even thought to turn off Ripple Editing at the point in question (middle of project), but I'm so freaked out about ruining my hard work!
Your advice would be greatly appreciated!
Bruce
You need to place a black color clip in between your clips and then place your title on top of that color clip. You can also add a cross fade transition at each end.
Then in time line view
Post by Black Lab »
Your problem has nothing to do with ripple editing.
You actually have specified the length for your transition. It is in File>Preferences. I believe the default is 1 second. Now, it's telling you your transition is too long and will be shortened because one of the two clips you are putting the transition between is shorter than 1 second.
You will either have to lengthen the adjoining clip or shorten your transition.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Jaeger...if you want to make a long addition to a project that is almost complete and you want to keep everything in sync...I'm afraid with such an addition at such a late stage something will have to give.
Usually it's Music track for me as that is the easiest to adjust later on and the track that blocks ripple editing (unless of course it all synced to the beat of the music in which case you'll have some work ahead of you)
So pick which ever will be the least work and turn ripple editing off for that track.
You should then be able to add colour or video with ripple editing enabled for the tracks that can move with the ripple.
