Analog video transfer to dvd
cgflembo
motherboard: Acer Inc Chapala
processor: Intel core 2 duo cpu
ram: 2gig
Video Card: NVIDIA GeForce 8600M
sound_card: Realtek High Def Audio
Hard_Drive_Capacity: 115gig
Post by cgflembo »
I am trying to transfer my old camcorder (hi8) and VHS tapes to the computer so that I can put them onto a DVD. I did buy `Dazzle dvd recorder` and tryed to do this through the USB port, but VideoStudeo 11 did not want to recognise the programme. At one time I did get a picture (without sound) but still could not transfer the video. I tryed composite and svideo without any joy. Is there anyone who has tryed transfering anolog to DVD, or onto the P.C for editing, and if so what programme did you use that would work with V.S11? If Dazzle DVD recorder is compatable, what settings do I have to make to V.S11 to make it except the programme. Idealy an attatchment that used the Firewire would be better.
cgflembo
DVDDoug
Moderator
Post by DVDDoug »
The Dazzle device should have come with capture software. Once you have a video file on your hard drive, you should be able to use Video Studio to edit and make a DVD. (I can't guarantee it will work... I think some have had trouble with the MPEG-2 files created by Dazzle.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
cgflembo
ram: 2gig
Post by cgflembo »
The capture software that came with the Dazzle device was Pinnacle Studio, but this was a trial version, and did not work either. Do you know of a divice that will work with V.S?
cgflembo
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
If the programme that came with the device didn't work, then it could be the device is faulty, or you have a problem on your pc stopping the video apps working.
By a canopus advc range firewire connected analogue to digital converter, capture using movie maker then import the file into VS for editing.
There is some sort of problem stopping VS from capturing analogue>digital signals at present in V11.
Devil
Post by Devil »
TedJohnson
Post by TedJohnson »
For me the easiest method is to use a VHS/DVD combination deck. The copying from VHS to DVD is easy; the hardware does all the work. The files on the DVD are superior to the VHS source (the software in the deck does all the work). These files can be easily edited in software of your choice (VideoStudio). I prefer to copy to DVD-RAM discs. Quality is outstanding and VideoStudio handles the conversion of the .VRO files to give easily editable MPEG files. At least this is what I do. By the way, if you do this, be sure to watch the field priority and keep consistent with the imported file. VideoStudio defaults this parameter incorrectly on the output side (for my projects this typically needs to be reset to UPPER field first).
Devil
Post by Devil »
TedJohnson wrote:For me the easiest method is to use a VHS/DVD combination deck. The copying from VHS to DVD is easy; the hardware does all the work. The files on the DVD are superior to the VHS source (the software in the deck does all the work). These files can be easily edited in software of your choice (VideoStudio). I prefer to copy to DVD-RAM discs. Quality is outstanding and VideoStudio handles the conversion of the .VRO files to give easily editable MPEG files. At least this is what I do. By the way, if you do this, be sure to watch the field priority and keep consistent with the imported file. VideoStudio defaults this parameter incorrectly on the output side (for my projects this typically needs to be reset to UPPER field first).
Editing from a DVD to make another DVD will mean at least some re-rendering with a consequent loss of quality, which may be significant. The raison d'être of such combination decks is to make DVDs for direct use without editing. I strongly recommend the analogue>DV converter option (eg Canopus ADVC-n) to maintain best quality with minimum hassle.
