Failed to create VOB file
mcwhirtj
Post by mcwhirtj »
I am runnng DVD Moviefactory for Toshiba 5.51.0018.0 Vista (a version that came pre-packaged on my laptop when purchased) When attempting to burn a DVD or just create an image, it gets about 8 minutes in and about 70% complete and gives me the error "Failed to create VOB folder" and stops. Right before this happens, the detailed progress shows that it is "building motion background of the menu" and then "building new transitions" and then it briefly states "Incorrect or unauthorized use of authoring tools" right before the pop up come up wih the "failed" remark.
Any ideas on what this could be? causing this?
Jeff
heinz-oz
Post by heinz-oz »
Vista user rights management comes to mind :wink: do you have read write access to the temp folders?
mcwhirtj
Post by mcwhirtj »
I'll have a look into the temp folder issue....assuming these are the temp folders related to this software, or located somewhere else? I'll also look at global settings. Thanks.
DVDDoug
Moderator
Post by DVDDoug »
I have no idea what that message means...
What format are your video files and where did they come from? The trouble is usually with the decoding rather than the encoding. (Movie Factory can make VOB (MPEG-2) files, but the question is, can it make a VOB file from your file?)
The Read This First... post at the top of the forum tells you what we need to know.
Or, you can try searching the forum for the format you are using. (i.e. Search for "DivX", "AVCHD", etc.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
mcwhirtj
Post by mcwhirtj »
It's right off a 30 min DVD from my Sony Hanycam DVD 550 I think is the model. I am guessing it is probably MPEG2 files. The raw data is files with extensions of .buf.ifo and .vob.
mcwhirtj
Post by mcwhirtj »
FYI, I aso disabled the Vista UAC so it shold have no problems creating a folder or have any 'rights' issues as suggested earlier. This had no effect however. :?
etech6355
Post by etech6355 »
I would re-activate UAC back to where it belongs.
Re-install the application over itself. Just re-install it again.
There is also an update to that program, the link is on the Canon drivers web site.
There's also a link on this forum, maybe if you search you can find it.
mcwhirtj
Post by mcwhirtj »
OK
Note sure what app you are referring to...the Moviefactory came pre installed with the Toshiba laptop and have no original program disk.
Canon? I have a Sony handycam.
Jeff
