Can I overlap video clips?
crossroadsglass
motherboard: Asus Z97-Pro
processor: Intel i7-4440K
ram: 32GB
Video Card: NVIDIA GTX 970
sound_card: SoundMAX Integrated Digital Audio
Hard_Drive_Capacity: 256SSD+4TB
Monitor/Display Make & Model: Asus ProArt 24" Dual monitors
Corel programs: VS X9-U, PS Pro X6 (64-bit)
Post by crossroadsglass »
When editing in VS8, am I able to overlap adjacent clips as a common transition effect? Thnx.
Thank you for your assistance. I'm very grateful!
Mike
"None of us are as smart as all of us." -Martin Lee
Welcome to the forums,
Yes you can. Just drag a transition from the Transition Library between your video clips.
crossroadsglass
ram: 32GB
Thx for such a prompt reply. I'm not sure I understand. When I insert a transition between the clips and then stretch it (to attempt an overlap), the transition effect simply gets longer/slower, but the two clips are still separate. What I'm wanting is to have one image temporarily superimposed on the other image as the transition effect.
Thanks again!
Mike
crossroadsglass
ram: 32GB
Hi Ron-
I forgot to mention . . . When I insert a clip into the timeline during the "Overlay" tab, it inserts a picture-in-picture, not what I think of as an overlay.
Mike
Post by Trevor Andrew »
Do not get confused with Overlay and Transitions/Effects.
The Overlay track is used to set an Image or Video over the top of the main track. It can be used for the Picture in Picture effect. ( the overlay track is the second track down )
Transitions are an effect used when combining two adjacent clips in the main/top track.
(transitions cannot be used in the overlay track)
Click the Effects tab and the library should show the transitions, there are lots to choose from.
Ok
You can set the transition duration from File-Preferences-Edit, try a setting of 4 seconds. ( also set the Insert Image Color duration to 12 )
The transition can be set to occur automatically every time you insert a clip. (to the top main track only)
Now
File-Preferences-Tick Use Default Transition effect
Select the transition you wish to use.
When you say ¡¥the clips are still separate¡¦, I think you are viewing the project in Storyboard view. This shows the video and effects as separate clips.
Switch to Timeline view to see the project as a continuous film.
Use the Zoom tool, the + and ¡V signs can expand and contract the timeline view, allowing you to see more or less frames.
Now do a test using the Image library as your clips, insert them to the timeline, each will be 12 seconds with a 4 second transition.
Hope this Helps
crossroadsglass
ram: 32GB
Thx Trevor-
Yes, I'm familiar with the differences between using the "Overlay" tab and the "Effects" tab, but I still don't have the result I'm seeking. When I use the Effects transitions, e.g., Peel, Turn, Flip, etc., I get the first clip which transitions via Peel/Turn/Flip/whatever into the second clip - but NOT SUPERIMPOSED on the first clip. I'm trying to simply superimpose (overlay) the first few seconds of the second clip ON TOP OF the first clip w/o any transition effect, i.e., the two clips simply BLEND TOGETHER. Do one of the Effect transitions allow that?
Thank you.
Mike
Try the Cross Fade transition in the FX library section
This will fade from one clip to the other. (but I do not think this is the effect you are after)
If you want to apply a transparency, ie one clip is partially transparent set over another then I do not think VS 8 supports this option.
I do not have VS 8 installed, otherwise I would give it a go.
Place your clip in the overlay track, click to select the clip, if Chrome effects are used they will show in the Attributes tab/ panel ( if you do not see then its not supported )
Using later versions of VS you can make one video clip transparent (0% to 99 %)
The Mask and Chrome Key options can produce this effect.
crossroadsglass
ram: 32GB
Trevor-
YES!
The transition that does exactly what I was hoping is F/X-Crossfade. Give it try in your version if unfamiliar with it. You actually see this transition all the time on TV news clips, and I was sure that Video Studio allowed it. The result is a soft transition from one clip to another. I like it!
Again, THANKS A MILLION FOR YOUR HELP! Have a great week.
Best regards,
Mike :D
mykoalabear
Post by mykoalabear »
"The transition that does exactly what I was hoping is F/X-Crossfade. Give it try in your version if unfamiliar with it. "
I have crossfade set as my default transition, all the others look too flashy by far to me!
However, for some strange reason this FX was not included in all versions of VS. It was in v4, but not in v7 (it's back in v11, thank goodness!) I copied the relevant file (fade.vfx) from v4 to the same folder in v7 and it worked perfectly.
Paul
Hi Paul
The X-fade transition is probably the most used of all the transitions.
It has been included in all the versions of VS that I own. (5-7-8-9-10) always under the FX page.
Make sure you have the latest DirectX installed
You have installed Intel Indeo driver from VS installation-Utilities option
There are some free transitions thanks to Stefan Burger
See
Free Stuff for use with Ulead Products
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=12931
Look down the list for Burger Transitions
Hope this Helps
crossroadsglass
ram: 32GB
Thanks again everybody. Most helpful!
Mike
