I use VS11 and capture in HDV at 1440x1080. My resultant .wmv files look much better when I finish cutting then when I shot in SD. But when I make a DVD out of the MPG2 file it doesn't look good. Lots of noise and odd light (brighter). I found the following comment on another board;
Editing in HDV to create a standard def video is much more difficult to get good results due to interlacing artifacts.
Some people are suggesting downcoverting out of my camera (Canon XLH1) but then I will sacrifice my .WMV side of the house I need to satisfy. I need to keep the bit rate of the DVD at/around 6,500 to burn to the standard DVD in the time frame I need on the media (45-90 minutes in a project).
Don't mean to cross threads here. I noticed my 1440x1080 stuff had to be cut at 720x480 and the aspect ratio not the same and posted about this but since, in general, I need to get a better DVD (if possible) out of the HDV output I started a new post.
Any help getting my DVD output better appreciated.
.WMV output looks great, DVD looks bad
heinz-oz
