Viewing using the firewire port as a pass through doesn't use much pc power. When you start to capture the pc has to write a lot of data at the same time as reading lots.breeder44 wrote: I didn't leave any services running except the Ulead
Your computer wouldn't run if you only had Ulead running!!
When I play the video from my camcorder to the computer it works fine, doesn't skip but as soon as I start to capture it drops 100 frames in 25 seconds.
What are your computer specs?
And as Steve said a while back,
What has changed? If your pc once worked well and now doesn't something must have changed, so rather than us running round trying to guess, can you tell us?sjj1805 wrote: So what has changed on your computer?
Have you installed or removed any software or hardware.
Has the computer had a sudden loss of power such as a power cut.
Is there a problem with your hard drive(s) - Windows Start | Run - chkdsk
