newbie question
phscyiipfer
newbie question
Post by phscyiipfer »
how can i delete all of my imported media files on the library of ulead10 all at once? after making a project the video clips that i have use doesnot clear up
please help...thnx
If you did as I do you will have used the Library Manager to create a library for the clips related to the project in hand. If so simply delete that library - they are simply thumbnails of your images not copies.
If you wish to delete clips from the library but leave other entries intact you can use the mouse to click the first clip you wish to delete, hold down the shift key and then click the last clip you wish to delete - this will select them all, then delete.
You can also select various clips by holding the CTRL key whilst you click the required clips.
To delete the clips themselves from your hard drive you also have to hold down the shift key when pressing delete, this will bring up an option to delete the clips in addition to the thumbnails.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
deleting files
Post by Ken Veal »
It makes things a lot easier if your clips ,files and projects are stored in the Library Manager then they can be deleted in one swoop.To access the L.M either Go Tools Lib Man or select it from the list via the drop down arrow next to where you change the library type.Choose the media type then new-name it,select edit to amend name/description if required.You can then delete the named folders and their contents in one go when you want to.
If you did not use the L.M. a project file will have a .vsp extention.
To delete non consequtive files - Select the 1st file then hold down control as you highlight each file then click delete +shift to delete them all.
To del consequtive files Select 1st file, +select the last clip which will highlight all inbetween then press del. + shift which will remove all those clips from the library.In V.S. 9 + later confirm that you want the files deleted from the hard drive too.In V>S> 8 + earlier deleting and icon will also delete the original file whether image,audio or a video file.
