Video Capture Crashes ENTIRE System whether it's Video Capture 7 or MediaStudio Pro > Capture, or anywhere I attempt to 'capture' video.
Yes, it used to work fine. Then POW.
I can OPEN VideoCapture Pro 7, when it's defaulted to playback, but the moment I click "capture" the whole system freezes.
I have a feeling that it's one of the capture settings [like a codec] but I can't get IN to change it cause everytime I open it to CHANGE it, it FREEZES requiring a reboot.
I'm stuck, ...
What next...uninstall....will that reset the registry, or will I have to manually adjust it, or....
Not easy to say. You don't give a clue as to HOW you use it (DV, analogue, codec etc.) or which version or OS you are using. The first thing I would do, if I were you is to uninstall MSP, delete all references to it, ANYWHERE in the computer, including in the registry, re-install it, update with SP3 and I'll give you a 95:1 chance it will work.
Most complaints of this type were a result of early use of SP2 with SP1 already installed.
Brian
Brian
thecoalman
