Microphones
contour
Microphones
Post by contour »
Hi - thanks for the help so far & hoping I got names right in my replies.
I've now started doing voice overs with audacity and making progress.
One problem though:
My Sony One Point Stereo Electret Condenser Microphone ( maybe twenty years old) produces clear but very low level input. I've managed to boost it with the rubber band and other options in VS 11.5 Plus but it is not really enough.
What my options are please?
Can I use a reasonably priced pre-amp or will I have to buy a new microphone? I've converted its pair of .25 inch stereo output plugs to the single twin motherboard input (using a Maplins UK converter).
Thanks in anticipation, warmest regards
grif.
Celtish
2Dogs
Post by 2Dogs »
Hi Grif,
glad to hear you're now Audacious! :lol:
Have you made sure that you have the input levels turned up in the Windows sound control settings?
On my system, which has onboard Realtek audio, I have a "speaker" icon in my system tray. I can click on that, or go to "Control Panel > Sounds and Audio Devices" then click on the "Advanced" button which brings up the "Master Volume" window. Click on "Options > Properties" which will bring up the "Properties" window. Check the "Recording" radio button and in the large box you should see "Stereo Mix" , "Microphone" and "CD Player". (maybe even some others, depending on your system)
You can check all of these, but certainly at least the "Microphone" box. When you click the "OK" button, you are returned to the "Recording Control" window. In that, make sure that the select box for "Microphone" is checked, and that the slider is all the way up. On my Realtek audio, there is an additional "Advanced" button under the Microphone settings. Clicking on that gives access to a "microphone boost" button which might just help.
If all the relevant volume sliders described above are already maxed out, you could be out of luck... :cry:
P.S. all of the above would have been much simpler with captured screenshots of the various windows, but I have yet to find a way of including those without linking to image hosting sites, which is a bit too clunky for quick replies. :evil:
contour
Microphones
Post by contour »
Thanks 2 Dogs
I think I've tried all that you suggest both in Windows Master Volume and in Audacity. But, after supper, I'll read your response more carefully.
I seem to recall that the ECM-99 always was a "quiet" microphone. I bought it for use with a portable Sony Stereo Tape Recorder TC - 152 SD and it gave good results. but that was a good twenty years ago.
warmest regards
grif
Celtish
dazzler2
Post by dazzler2 »
One of the best investments I've made for sound recording, narration etc was to purchase an Olympus Digital Voice VN-4100PC recorder for about $70. It functions as;
a An external voice recoder creating a new file which it places in one of its four folders each time you start/stop recording.
b It has an immense capacity and can record high quality music.
c functions as an external quality mike, feeding the recording directly into the PC instead of having to transfer the file later.
d Permits high quality narrations.
Dazzler2
contour
microphone
Post by contour »
Thanks Dazzler2
Sounds interesting, will check out here in the UK
warmest regards
grif
Celtish
GuyL
motherboard: ASUS P6T
processor: I7 920
ram: 6GB
Video Card: ATI 5870
sound_card: Auzentech X-fi Forte 7.1
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG W2753V & HP w2408h
Post by GuyL »
I use a Samson CO-1U mic. It is a USB mic that works very well. I have it on a stand that sits at the coner of my desk and I have the arm coming over to hang the mic just above my eye level. The mic is upside down. I look like I'm playing radio host but it works very well.
http://www.samsontech.com/products/prod ... rodID=1810
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
contour
microphone
Post by contour »
Thanks GuyL, will study your suggestions. I'll let you all know how I get on with my eventual outcomes.
warmest regards
grif
Celtish
mykoalabear
Post by mykoalabear »
I bought a clip-on microphone from Dick Smiths for $9 and surprise surprise it's rubbish! Same problem as the OP, low levels - you have to almost touch the thing to get any volume, and then of course you get distortion and breath noise.
I guess you need to shell out for a decent mike if you're going to do voice-overs on a regular basis. Nothing much on eBay unfortunately...
Paul
contour
microphone
Post by contour »
Thanks Paul and thanks everyone for the help given.
I've bought a stereo phono pre-amp for £25Gb from Maplin SP-24B www.maplin.co.uk I think. Whilst unfortunately I have to use the line input to my computer and there is some acoustic feedback if I'm not careful, I'm getting good quality voice overs with room to manouvre either way volume wise.
I've also bought a USB turnable from the same source and it seems OK at £79.99GB.
Thanks all
grif
Celtish
2Dogs
Post by 2Dogs »
So now your master plan for world domination is almost complete, Grif!
Should we expect to hear your eery voice as all our TV screens are taken over by your fiendish plot? :shock:
contour
microphone
Post by contour »
Yes 2Dogs - its a Celtish plot so beware of the melifluous tones.
Yet, there's still a lot of elevation still needed on the 11.5 plus learning curve to achieve that domination. It could take a long time with lots more questions to be put.
Incidentally, there seems to be reluctance to show a GB pound sterling sign in these postings, I've noticed from my last posting.
Remember, never forget the tripod.
warmest regards
grif
Celtish
2Dogs
Post by 2Dogs »
You're right - I'd never noticed that before with the GBP's - but I tend to convert mine into $$, since the exchange rate has been pretty good for a while!
¢G is what I get from the GBP sign on my (UK spec) laptop on this forum. There might be a way of using the character map to generate the real character - perhaps sjj1805 could point us to one of his tutorials on the matter! :lol: :lol:
mykoalabear
Interesting. I can insert the Pound sign, Yen and Cent symbols in the text box by using the ALT + commands, but when you preview, they're all replaced with ?
Paul
mykoalabear
Paul
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
I was impressed with the levels but for a mic I was forced to use a logitec combo headphone/mic I bought for my partner for her Skype account.
After some experimenting I found if I tuck the swivel mic under my chin and not move my head around too much I get good clarity and volume.
