VS8 won't recognize DVD disc
jeffreyrsears
Post by jeffreyrsears »
When I try to burn a DVD fromVS8 'Create Disc' mode; I'm getting an error message that disc is not empty or disc is not in the DVD burner even though I just put a new DVD RW disc in and I was able to copy other files to a disc minutes ago from my file manager??? :cry: :?:
joetg
Post by joetg »
When you get to the last screen before rendering/burning begins, click on "burner advanced settings". Check "format DVD+RW". This should work for you.
Joe TG 8)
thecoalman
Post by thecoalman »
If you haven't applied the updates there are specific updates for burning issues.
THoff
Post by THoff »
Also, DLA (Drive Letter Access) utilities such as Roxio's Drag To Disk will interfere with the UVS burning module, because they will mount the blank disk and assign a drive letter to it. You will have to close the DLA software, if any.
joetg
Post by joetg »
I had the same sort of problems when I had Nero installed. Every time I went to burn, Video Studio would shut down, as well as Nero's "In CD". A simple uninstall of "In CD" brought everything to normal.
Joe TG 8)
