Using VS8-SE. I have a 3.1GB MPEG file created from a VHS tape using the capture routine.
If I go immediately to the "Share" routine to burn a DVD the size of the file is 6.2 GB and it won't fit on a 4.4GB DVD.
If I bring up Movie Factory and send this same MPEG file to a DVD the file is only 2.6GB in size and then fits on a standard DVD
If I bring up Roxio's DVD builder with the same MPEG file the file size is 3.2GB and fits on the DVD.
So, wanting to use VS8 instead of the other programs there must be something that needs to be changed in VS8 that makes this file so large compared to the others. Any ideas would be appreciated....
Retired Tech
MPEG file too large for DVD
settings
I'm not sure what limitations the SE version has, but VS8 is similar to any other NLE. If the file was capture in ULead, then it should have automatically set the PROJECT SETTINGS to the same as the file (resolution and bitrate). But for some reason, the DVD authoring doesn't get the message. You need to set the DVD project to the same as the video project.
When you click on CREATE DISC. there is an icon in the lower left that looks like a Gear. Click that and change the settings.
Phenom X4 965 3.4Ghz, 8gig DDR3, 120GB SSD, 1TB HD, 500GB, Bluray & DVD Burners, ATI HD5550, Epson scanner, Canon 9000Pro, Sharp AL1551CS laser printer, Sony TRV740 8mm digital, Canon HV20 and Sony SLTA65VK, Win7 HP 64bit
Gary Russell
TNUSA
Gary Russell
TNUSA
Retired Tech
Thanks for your response. Yes, both options worked for me. Of course it had to convert back to a smaller file and that took 3 hours! Funny that same file worked ok in other programs! Oh well...
