Problem upgrading VS10plus to VS11plus, need help....
footsie77
Post by footsie77 »
...hi to all, hope u can help me with my problem.
...i have a vs10plus & recently purchased vs11plus upgrade, the problem is it didn't upgrade the vs10plus, instead, it installed into a separate folder and now i got vs10plus & vs11plus under ulead systems on program files...
...how do i keep only the latest version? is the vs11plus upgrade only 140mb?
...i'm disappointed because i only now have one menu template on vs11plus
...any help is appreciated, the reason why i upgrade is to get more menu/templates to use with dv-dvd conversion...
...thanks in advance!
Welcome to the forums,
VS does not over-write previous versions. Each version is a complete stand-alone program, so you can have numerous versions installed at one time. Currently I have VS 10+ and 11.5+ installed, however at one time had versions 8, and 9 installed as well.
You should have received more than 1 link to download files, when you purchased the upgrade. You will need to download and install at least the second file which has all the content for the program. The third link, contains bonus files, such as video, audio, examples to use, and a freebie version of WinDVD. If you did not get the additional links in your email, you can go HERE, to download those files.
Once you get the program fully installed you then need to go to Ulead's website to download and install 2 more files, the Update Pack, and the Power Pack. http://www.ulead.com/tech/vs/vs_ftp.htm. Unless you had the problems mentioned in the notation under the Hot Fix, do not install it.
Once you have completed all that, then you will have the complete program, and find many more templates to choose from.
footsie77
Post by footsie77 »
...Thank you for the reply, i was able to install the complete VS11 plus but another problem arise.
...the 9 minute limit capture, i'm using dv-dvd option and once it starts scanning, it stops on the 9 minute part and would just not continue...
...has there ever been a solution to it? i'm running vista....
..can i transfer menu/templates from vs11 to vs 10?
...any alternate program that does good dv-dvd transfer with nice menu/templates to choose from?
...any help is appreciated...
Post by Black Lab »
Please don't double post.
