Need help with transitions
GLORIA
Post by GLORIA »
I would like to have a different transition for each photo in my slideshow. I am using the full version of PS4. I can't seem to figure out how to do this. Each photo has the same transition. How do I make it change with each photo?
Sorry but you can't.
CD&DVD PS is designed to make things as easy as possible to create a slide show with no technical knowledge required.
To make more elaborate slide shows you need to consider one of the following in order of ease of use:
MovieFactory 6+ (Includes a random transition option)
WinDVD Creator (You can select different transitions between each slide)
VideoStudio 11+ (You can select different transitions between each slide)
AlphaDood
motherboard: Dell Inc. 0K068D A00
processor: 2.40 gigahertz Intel Core2 Quad Q6600
ram: 4GB
Video Card: Intel G33-G31 Express Chipset Family
Hard_Drive_Capacity: 4499.49 Gb
Post by AlphaDood »
You do have a limited choice to apply transitions to the slide show. If you go to "Theme" tab the look to the right you will see three tabs. Gallery, Menu & Slideshow. Select "Slideshow" then look towards the center of that group you should see "Transition Effect" click on the selection which will bring up a small window to make your choice. There is a drop down arrow to select with the choices available. Select "Combination" and you will have the different or random transitions applied to the slideshow. Hope this helps.
Dwayne
Thank you AlphaDood that makes it the same category as MovieFactory in the list above.
:D :D
