VS11 crash when trying to capture video.
imadork8317
Post by imadork8317 »
I have a JVC GR-D350U, and i have it hooked up through ieee 1394. when i start VS11 it and click dv to dvd wizard. i get the following message
"Ulead VideoStudio has encountered a problem and needs to close. We are sorry for the inconvenience."
Error signature
AppName: vstudio.exe
AppVer: 11.0.0.0
ModName: iviavctl.dll
ModVer: 3.1.24.9
Offset: 000a290b
Technical information
Exception Information
Code: 0xc0000005
Flags: 0x00000000
Record: 0x0000000000000000
Address: 0x000000000b01290b
Any help would be greatly appreciated! Thanks
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Hi and welcome.
You have connected to the PC correctly via firewire for your Mini DV type camera.
Open VS, choose the capture tab. Make sure your Mini DV camera is set in "play" mode... And proceed to capture.
With VS I'm sure you will be tempted to at least out some titles and edit out some video you don't want.
imadork8317
Clevo wrote:Hi and welcome.
Clevo, thanks for your reply however my problem is not that simlpe to fix, as i said before anytime i turn on my camera to play mode VS crashes with the error i specified above.
2Dogs
Re: VS11 crash when trying to capture video.
Post by 2Dogs »
imadork8317 wrote:I have a JVC GR-D350U, and i have it hooked up through ieee 1394. when i start VS11 it and click dv to dvd wizard. i get the following message
Do you only get this error when using the DV to DVD wizard?
Can you successfully capture by opening VS and then going to the capture tab instead?
Have you loaded the latest DirectX 9.0c update?
imadork8317
I get this error in the wizard and in the capture tab, and yes i do have the latest DirectX.
To furture clarify, I have my current device set to MS 1394 Device Control
Offset is 0
Current capture plug-in is IVI Capture Component, none other avaliable.
2Dogs
Post by 2Dogs »
Well, from the error information it looks like there is a problem with IviAvCtl.dll.
On my pcs, I note that there are different versions of the file.
I have the InterVideo editing program WinDVD Creator 2 installed, and that copy of the file is dated 10/18/2004 and 1.261 KB, appearing in both C:\Program Files\WCreator 2 and C:\Program Files\InterVideo\Common\Bin.
A more recent version, dated 3/6/2007 and 2,802 KB is found in C:\Program Files\Ulead Systems\Ulead VideoStudio 11\AVControl.
On one of my laptops, on which I have the DVD player WinDVD Platinum 4 there are also two copies of the file, dated 27/11/2002 and 833 KB in C:\Program Files\InterVideo\WinDVD4PR and C:\Program Files\InterVideo\Common\Bin.
You might do a search on your pc - and should find the same size file in the C:\Program Files\Ulead Systems\Ulead VideoStudio 11\AVControl folder. In your post, however, the file version is correctly shown as 3.1.24.9. so maybe it's just a long shot. If the file isn't there or is of a different size, you might try re-installing the program or even inserting a copy of the file into the folder.
To satisfy my own curiosity, I'm going to try substituting the various versions of the file into my Ulead folder to see if they all work for capture....
Update: I substituted both copies of IviAvCtl.dll from the other folders into the Ulead folder - and was still able to successfully capture video from my miniDV camcorder.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Can you capture with any other software, such as movie maker, already on yor pc or something like Windv?
imadork8317
skier-hughes wrote:Can you capture with any other software, such as movie maker, already on yor pc or something like Windv?
If i try to capture with windows movie maker, it says "an unknown error has occured" it doesn't crash, but no matter what i try that error keeps coming up. Every now and then i will get an error that says "Class not registered"
