I need some configuration help with creating the final dvd in high def format with 1920x1080. I read posts for hours last night and still couldnt find the solution. Here is what I have done so far.
Equipment: Sony hdr hc3 high def camcorder, vs 11 plus, windows vista
1. Captured my video via firewire cable using the DV type-1 format (per Ken B. suggestion on a prev post). Odd thing is even though i set the project properties to 1920x1080 it still showed 720x480 in the information box.
2. Created a template with all the good specs in the movie manager
24 bits, 1920 x 1080, 29.97 fps
Lower Field First
(MPEG-2), 16:9
Video data rate: 25000 kbps
Audio data rate: 384 kbps
3. Share -> Create Video File with the specs above
4. So here is where I have the issue. When I go to create disc and choose DVD there are no formats in anything higher than 720x480. Is there a way to burn the 1920x1080 to a regular dvd? thanks for your time
