After upgrading from PI11 to PIX3 I can't open my Minolta 7D RAW files.
My camera is listed as a supported camera.
Your help is appreciated.
Thanks,
Bill
Can't open RAW Files
heinz-oz
It does it with all RAW files on my computer.
It's as if the RAW engine did not install.
I need to know what file runs the RAW engine, and where it's looked on my system. If I did, I could look and see if it's there.
Then it's there, it would be nice to get my hands onRaw engine and reinstall it. But my product download is one big CAB file, and I don't know what file I need to re-install.
Thanks,
Bill
Bill
heinz-oz
I think you have a corrupted installation. Completely remove PI from your system. BTW, what is your system?
Here are some instructions meant for XP systems. You will have to apply a bit of lateral thinking and substitute the pointers to the software version with X3 and the Ulead may need to be replaced by Corel also.
Note: Make sure you still have a copy of the installer before you uninstall the software. Before installing, please temporarily close other running programs or applications including antivirus, norton utilities, screensaver, other memory resident programs including Internet connection, etc. to avoid unnecessary conflict and restrictions within your system.
Procedure as recommended by NickD
To reinstall the program here are the steps that Ulead suggests:
1. Please launch Windows Explorer and go to Tools>Folder>Options and on the View tab check "show hidden files and folders".
2. Empty contents of your Temp folder under C:\Windows\Temp.
3. Uninstall Ulead PhotoImpact using the Add/Remove Programs from the Control Panel.
3a. Goto C:/Document and settings/ and under each user listed look for a folder called Application data. Here you may find a Ulead Systems/PhotoImpact folder. If you do open it and delete the folder corresponding with the version you are trying to re-install.
4. Go to C:\Program Files\Ulead Systems then delete the PhotoImpact folder.
5. Go to Start > Run and type: "regedit" then click OK. This will open the Registry Editor program. Go to C:\Program Files\InstallShield Installation Information and delete the following folders if they are present:
{FE58B892-3825-4610-A6A2-E6EFCA83BD97}
6. Go to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > Current Version > Uninstall and delete the following folders if they are present:
7. Locate the identity enclosed in curly brackets that corresponds to Ulead PhotoImpact, delete the said entry.
8. Please delete all PhotoImpact folders on the ff: HKEY_CURRENT_USER\Software\Ulead Systems\and HKEY_LOCAL_MACHINE\Software\Ulead Systems\
9. Close regedit and restart your computer.
10. You can now proceed to reinstalling PhotoImpact. Be sure to logon as Administrator before installing your software to avoid restrictions.
Note: Before installing, please temporarily close other running programs or applications including antivirus, norton utilities, screensaver, other memory resident programs including Internet connection, etc. to avoid unnecessary conflict and restrictions within your system.
Nick
I hope this will get your problem solved.
Nick
Thanks Heinz
Thanks Henz, PI X3 is working properly.
I followed your steps only up to step 3.
Here's what I did
---> I did this
---> I did this
---> But here's where I did somethning different, but it fixed my problem.
Instead of uninstalling PI X3, I clicked REPAIR. When repair finished I opened X3 and I was able to open RAW files too. Good enough for me.
Here's what I did
---> I did this
---> I did this
Thanks,
Bill
Bill
heinz-oz
