Photoimpact x3 I need help!
naenae
Post by naenae »
So I had pi 11 then I got a new cmp and it was vista and I have been using pi 11 on vista tho it has probs being its not made for vista so I got pi x3 today it was a gift for winning a contest. My prob is I cant get it installed on the cmp I put in the disk and the auto run does not start and it wont show that i have a disk in the drive so I cant set up any thing and I tried downloading the trial of x3 then entering the serial code but that dint work soooooooo now I cant play with x3 on this cmp can some one help me get it to work on here!
heinz-oz
Post by heinz-oz »
Your problem is not with PI, it's with Vista. Are you logged in with Admin rights? You need to get help from whoever supplied you this computer in order to install.
naenae
Post by naenae »
yes i am logged in with admin rights so do I just take it to best buy and tell them to install it?
Sounds like you have either a faulty disc or disc drive.
To check if its a faulty disc try and copy the contents of the disc to a hard drive folder using Windows Explorer. If it copies across then try running the installer from the hard drive.
If it fails to copy then see if another computer will read the disc.
Vista works slightly different to XP when it comes to installing programs, anyone logged onto Vista is treated as a User Account and not an Administrator. When you try to do something that needs administrator rights Vista presents you with a series of nag screens along the lines of
"Do you really want to do this?"
"Are you absolutely sure?"
You can over ride the above by turning off user account control - but remember to turn it back on again when you no longer need it turned off.
naenae
Post by naenae »
well I installed the cd on my other cmp and it worked and I fixed all the admin thingers but I did this thing. Its a program compatibility wizard amd it says how do you want to locate the program and I put I want to use the program in the cd rom drive and it tells me wizard could not locate programs on your cd click okay to retry.So I think some how my rom drive got dealted or some thing and I have no clue how to fix it
