HDV (1080i) Title is bed size
Arekwp
Post by Arekwp »
Why
Project 1440/1080
video source HDV Sony FX1/Z1
Add title - title visible format 4:3
WHY ??
intersilmultimedia
Post by intersilmultimedia »
I don't understand the question. What exactly is the problem?
Intersil Multimedia
www.intersil.com/movies
Gorf
Re: HDV (1080i) Title is bed size
Post by Gorf »
Arekwp wrote:Why
Project 1440/1080
Because 1440:1080 is 4:3
VideoKillers
Post by VideoKillers »
Format DV 720*576 is 4:3 - I'm use my sony vx2100 in 16:9 format.
HDV is 16:9 NOT 4:3.
Devil
Post by Devil »
HDV 1080i in 16:9 ratio is 1920x1080, not 1440x1080. Your cam shoots anamorphically in 4:3 to give you the impression of 16:9.
VideoKillers
If DV 16:9 visible video source on text window in 16:9 why HDV visible 4:3 ?
Devil
Post by Devil »
DV 16:9 is letter-boxed. HDV 1080i 16:9 is 1920x1080. If shot in 1440x1080, it has anamorphic compression, because 1440x1080 is 4:3.
Blame the camera for being 4:3!
Gorf
Post by Gorf »
Devil wrote:DV 16:9 is letter-boxed....
No it isn't. DV is 720x576 or 720x480 regardless of the picture aspect ratio.
Devil
Post by Devil »
Exactly, that is what I said: it is letter-boxed. If used in 16:9, only the centre 720x405 pixels are used for the image, the rest being black. AFAIK, I don't think DV cams had anamorphic compression for 16:9. Both my high-end cams have letter-boxing (which I never use!) with the reduced vertical pixel use. Actually, I think it is bloody useless! :shock:
troppo
Post by troppo »
My camera will shoot 16:9 DV without letterboxing. It's still 720x576, it just changes the pixel shape to get the 16:9 ratio.
Devil
Post by Devil »
OK, some may have anamorphic compression!
Gorf
Post by Gorf »
My 10-year-old consumer Sony and 5 year old "prosumer" Canon both use anamorphic squeeze to yield widescreen.
Which ones letterbox?
Devil
Post by Devil »
Both my Panasonic 3-CCD machines do.
Gorf
Post by Gorf »
OK having read up on it a bit, it sounds like it's a setting available on some cameras- you can either use full-frame 16:9 or letterboxed 4:3.
Although full-frame should be better because the whole DV frame is being used for compression, some cameras (Sony was mentioned) introduce edge artefacts when stretching the crop to fit the frame. In these circumstances you should, if your camera supports it, letterbox to 4:3 as the black borders will compress well, leaving more of the bitrate for the actual picture. Otherwise, shoot 4:3 and crop to 16:9 in the editor.
Not that any of this tangent helps the OP at all...
