SmartRender
sayer
SmartRender
Post by sayer »
I have, Mf6+, WinTV PVR 350, Windows xp pro
Can anyone help please,
I am new to all this!
I have captured tv program with the winTV PVR 350.
When I go to edit it, I get this message, what should I do?
Project Properties
MPEG files
24 bits, 720 x 576, 25fps
Frame-based
(DVD-PAL), 4.3
Video data rate: Variable (Max, 7000 kbps)
Audio data rate: 256 kbps
Dolby Digital Audio, 48 KHz, 2/0(L, R)
Video Properties
MPEG files
Upper Field First
(DVD-PAL), 4.3
Video data rate: Variable (Max 4400 kbps)
Audio data rate: 384 kbps
MPEG audio layer2, 48 KHz, Stereo
Which are the best settings to use, so I can play back on my TV or my computer
DVDDoug
Moderator
Post by DVDDoug »
SmartRender means that your file will only be re-rendered where where required by editing or applying filters, etc., or if required to make your video DVD-compliant.
Your file is already PAL-DVD compliant. If you check the box that says Do Not Convert Compliant MPEGs, your file will remain unaltered. (Your Project Properties will be ignored.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
