Hi Everyone
Have finally mastered the recommended workflow which negates the bugs in UVS8.
I have one final question:
One is recommended to create the mandatory video file prior to DVD burn.
When you do this and then go to share/create disk and then add video....
You always seem to end up with a main menu and then a secondary menu when you add/edit chapters.
Ie when you burn the DVD you end up with a main menu which you activate to find the chapters you have just created.
Its not the end of the world but is this the consequence of creating a separate video file before burning the DVD.
Your advice would be much appreciated.
Antonio, Anna y Eduardo Felipe
Comedy of erors or alls well that ends well
Antonio y Anna
jchunter
Tony,
I'm glad to hear that you have burned a good DVD.
No, its not a consequence of using video files.
I usually keep each of my projects short (5 - 15 minutes) and make a video file of each one. When I burn a DVD, I usually add several video files. Each one has a top level menu and its own submenus. So, when I play the DVD, the opening screen shows all the top level menus. Then I can select any one of them and drill down to the detail level for starting playback.
John
John
