What is the SPEED / QUALITY slider in VS8 for?
It default at 70 through a QUALITY of 100.
Speed Quality Slider - What For?
oka
- motherboard: HP h8-1100z
- processor: AMD FX-6100 Six-Core Processor 3.30 GHz
- ram: 6 GB
- Video Card: AMD Radeon 6700 PCIE 1GB GDDR5
- Hard_Drive_Capacity: 1.1TB Free
- Monitor/Display Make & Model: Gateway LP1925 Monitors - Two
- Corel programs: VideoStudio X8
if you need something "fast", move it towards "speed", if you want better quality, move it towards "quality"
It's how the encoder will convert your source video. If speed is your priority, the encoder won't spend too much time analyzing while encoding your video. You get your output faster, but it might not be the best quality. If "quality" is more important, then moving the slider towards "quality" will allow the encoder to take more time to analyze your video for compression (motion search...). It will take longer to encode, but your results should be better.
It also depends on your source video (what type it is, how clean it is, etc...). So adjusting the slider will be a personal thing for you to decide what is the best combination of speed and quality...
George
oka
- ram: 6 GB
I Believe In Quality Than Quantity
Thanks.
I think I will move it to the end (100%). I'd rather spend more time to get the best quality I can since the discs I write are to be kept "forever".
Thanks again for you info.
Caxtin
