file tipe mod
jcarlospascual
file tipe mod
Post by jcarlospascual »
My camara JVC Everio creates files type MOD that I cannot use with the
program. It says that it does not tie east file
thecoalman
Post by thecoalman »
The specs say it records in Mpeg2 which is DVD format. Try changining the extension to .mpg If that doesn't work your transferring the footage wrong, since its based on a drive 8) you should just be able to browse from My Computer when it's connected to your computer.
Find the movies files and copy them to somewhere on your HD, should be as simple as that. Import them into VS8 for editing.
That is probably the first camera/cam unit that I have seen that may actually be worth using for both video and still pictures. Must be a small fortune. :wink:
jcarlospascual
It pardons, I speak Spanish and I do not understand to you well. I
need any codec. where with himself? like changing the extension mpg.
I have been going to change file name and have put vvv.mpg but it has
not worked either
