Transition problem
bkersh1
Transition problem
Post by bkersh1 »
Has anyone ever had a problem where the transition you select and move to the timeline is not accurate? I select the "fade to black" and the "Accordion" is there???
I havent checked others but i am wondering if i should uninstall and reinstall the program.
bkersh
Post by Black Lab »
No, I can't say that I can recall hearing of this problem before.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Never heard of that either!
It does tend to suggest that somehow your installation has become corrupted.
If you have the original install CD try the repair function or,
failing that,
do a standard uninstall/reinstall or,
failing that,
do a search of "Clean install" on the board, follow the instructions then re-install.
PuzZLeR
Post by PuzZLeR »
This is strange indeed. :?: Never experienced it myself either. I'm assuming the problem suddenly happened instead of always being there from the start.
Maybe you renamed, updated, or switched a file accidentally somewhere. However a delicate surgery to go through your install directory could make matters worse. I would just uninstall the app cleanly and reinstall fresh.
UVS tends to build lots of baggage given enough time, and this problem is just like others too that you can relieve yourself of in only 10 minutes of time. Don't even bother trying to figure this one out... :roll:
Make sure it's a clean uninstall otherwise it may not be fixed.
bkersh1
Post by bkersh1 »
Thanks for the help. I have gone ahead and uninstalled-reinstall and it seems to work fine. It was weird! I am sure i did something along the way.
bkersh1
