Then once all your editing is complete, in VS go to the Share>Create Video File step, and choose NTSC (or PAL, depending on where you're located) DVD. This will render your project to a DVD Compliant MPEG2 video file. DVD(SD) specs require that the video files be in the MPEG2 format, not DV or AVI. This step may take several hours, depending on the complexity of your project and your computer.
Once your DVD Compliant MPEG2 file is completed, go tot the File menu and select New Project. This will clear the timeline. Do Not place anything in the timeline. Go back to the Share Step, and this time select Create Disk. This will open the Burn Module.
Now insert the DVD Compliant MPEG2 you just created. Continue on building your menus, adding chapters ect., until the final step, which is where you burn the disk, Create DVD Folders, or a Disk Image file. Since you have Nero, you can at this point uncheck the Burn to Disk option, and check the Create DVD Folders. This is what's commonly called burning to your Hard Drive.
Creating DVD Folders has the benefit of being able to view your finished product using a software DVD player, before burning to DVD. If there are errors, or you don't like something, you have not wasted any disks. You can go back to your project and make changes. Doing so, remember that you will have to render another DVD Compliant MPEG2, and go through the steps in the burn module.
Now if everything is great, you can open Nero and burn your DVD, using the DVD Folders that you created with VS11+.
But I have just realised that although I started off this way after a short break from making my DVD's, when I resumed I thought I was still doing them this way but had in fact changed what I was doing to the following.
At the CREATE VIDEO FILE (after doing all my editing and having my project ready on the timeline) stage right at the beginning I was now selecting SHARE instead and then selecting CREAT DISK which opens the BURN MODULE with my timeline piece already in place. After a couple of clicks and menu selections I get to the bit where it says CREATE DISC, which I uncheck and check CREATE DVD FOLDERS instead to create a copy on my harddisk before burning an actual disk with NERO.
Obviously I have spotted my error now although the DVD's I produced seemed fine and can rectify this but what I would like to know is what difference there is between the two ways, i.e. Am I losing anything/quality by doing it the latter way as it is quicker?
Can anyone break this down and explain the differences between the two ways, and the consequences for me please, as I cannot quite get to grips with what difference it makes.
