Hi All
Has anyone created the "Transparent Video" using MSP8 - I need to create something for a web site where a person walks around the page.
There are examples at:
http://www.wildform.com/demos/Transpare ... hannel.php
http://www.totalwebvideo.com/
So the question - can I create an effect like this on a web page using MSP8
Transparent Video
That's interesting, I hadn't seen that before. I'm not sure if it's an effect as spectacular as the totalwebvideo guy makes out it is, but i guess he's a salesman.
If you do a green/blue screen effect and key out the background and then import this into flash maybe? I'm not sure if flash recognises alpha (transparency) channel, but once you have your person walking around your flash page you can use layers to add text either in front or behind the little man (or woman)
Good luck.
Good luck.
Re: Transparent Video
It looks like that's just a green-screen effect. MSP 8 handles that very nicely - just shoot the person walking around in front of a blue or green screen (I use a bunch of green "construction paper" taped to the wall of a spare room in the basement). Once you've got the video, put the background video on the Video1 track (or, you could just use a colour clip like White), and then put your "green screen" video on the Video2 track. Then, drag either the Green Screen or Blue Screen overlay onto the clip on Video2 track and render the video...Keith wrote:Hi All
MSP8 makes it easy. It was a little tougher in MSP7, but still workable. As far as the web page goes, you'll need something to convert your rendered output into flash for your web page (I haven't done that part of it).
For information about the green screen process, check out some of Nick Jushchyshyn's tutorials at http://www.jushhome.com/nick/tutorials.asp. I'm not sure if his tutorials have been updated for MSP8 or not, but they certainly will provide lots of background information for you.
I hope this helps.
Al
Keith,
You can use Riva FLV Encoder 2 to encode your edited video to .flv
It's free!
http://www.download.com/3001-2140_4-103 ... dac05276d8
It's free!
Perhaps they've overlaid a transparent image map or something (if that's even possible)? Although I have a couple of web sites, I'm not much of an html guy so that's beyond anything I've ever done...Keith wrote:Thanks asande
That's useful but I'm sure on some of these sites the web page is still active and you can still click and navigate?
Al
The website with the guy walking out is just using an embedded flash file. Not that big of a feat, provided you have a decent flash authoring program.
With that said it is possible to create web pages that use a sort of HTML/XHTML, CSS and Java Script, embedded in the Flash. The web page appears as a normal HTML page, however is actually embedded within the flash file. It requires very complex coding, using not only a good flash authoring program, but expert knowledge in CSS (Cascading Style Sheets), XHTML, and Java Script.
To create the small video, like that guy walking out, just create a video using chroma-key (green/blue) screen. The video would be brought into your flash program. In your flash program design your layers, the background and any foreground of your website that overlaps into the area of you video. Export the video as a SWF or FLV. Embed the video in your HTML page.
If you use FireFox, and have the DOM Inpspector add on, you can view the code used to create that web page. He uses XML, CSS, and Java Script, along with the flash video.
