Internet Explorer not found?
Moderator: lata
Al K. Hall
Post by Al K. Hall »
I received an Intervideo software bundle with my motherboard (Asus Striker Extreme), when I open any of the programs I am presented with a product registration popup.
I select the option to register, but I then receive another popup that says 'Internet Explorer not found. Internet Explorer is required to register' or some such nonsense.
Since I am absolutely certain IE is installed (I use it all the time, unless there is another IE I am unaware of) I am hoping someone can help me resolve this issue.
Corel tech support apparently cannot answer an email, so I am asking in this forum.
Welcome to the forums,
Bundled free versions, like you received with your motherboard, generally do not require any activation or registration. Reason being is that the vendor that bundled the software with their hardware receives a block license for all the software they are going to provide. It's a means for the software companies, like Corel to advertise.
Since WinDVD was originally developed by the former Intervideo, I'm not sure that any links contained in the programming are current. If in fact it was able to find IE, it most likely will be a dead link.
However Corel does provide some instructions when having problems with activation. I tried providing a link to the answer, however Corel uses paths that do not allow this.. :twisted:
So here is what it says about How do I download and/or Activate my product
This article contains two sets of instructions:
I already have the product installed on my computer -
I do not currently have the product installed on my computer -
Please follow the instruction set for your current scenario.
Answer
If you already have the product installed on your computer, you may use your serial/purchase key to activate the program.
1.
Open the product and then close it.
2.
You will get a dialog with a button titled "Activate now!"
3.
Click on Activate now!. The program should automatically be activated in a few seconds.
4.
You will get a confirmation asking if you would like to Save or Print your activation information. Choose your desired option.
** If you get any errors or have problems activating the product online, follow the instructions below:
1.
Disconnect the computer from the internet (with dial up accounts, just disconnect the dial up connection. With broadband accounts, disable the network connection option by doing the following:
a. Go to Start | Control Panel.
b. Double click on Network connections (if in Category view, click on Network and Internet Connections, and then on Network connections on the following screen).
c. Right click on the Local Area Connection icon and choose Disable.
If you have any problems with the above procedure, an alternate option is to physically disconnect the Network Interface Cable from either the back of the computer or the HUB that it is connected to.
1.
Launch and close product again
2.
Click the Activate now! button.
3.
Click on Phone Corel.
4.
You will be offered an Installation Code and your Key with a blank Activation Code field.
5.
Contact Customer Service by phone by clicking the Customer Service button or contact Customer Service through the Corel.com website from this link http://support.corel.com/scripts/rightn ... td_alp.php
6.
Provide Customer Service with the Installation Code and Key and you will be provided with an Activation Code that can be used to unlock your product.
If you do not already have the product installed on your computer, you will need to download the program prior to activating it. There will be two different places you may download from:
1.
You will be directed to a Order Confirmation page with a link that says Click to Download just after your order has been completed.
2.
You will be emailed an Order Confirmation Email with a link that says Click to Download.
Download Instructions:
1.
Click on the Click to Download link on either your Order Confirmation Page or in your Order Confirmation Email.
2.
Make sure to keep an eye out for any pop-up blockers that may be triggered by your browser or internet security software.
3.
You will be offered a File download dialog. Choose to Save the file.
4.
Save the file to a place you know where to find it such as your Desktop.
5.
Once the file has been downloaded, double click the file's icon to initialize the program's install.
6.
Follow the install wizard to install the program. You will be prompted to enter your serial number.
7.
Use the Serial Number provided on either your Order Confirmation Page or in your Order Confirmation Email.
8.
Open the program and then close it. Follow the instructions provided above under I already have the product installed on my computer - to activate the program.
To search further go to Corel Support/Knowledge Base. Type in your questions, and start looking through all their goofy responses... ;)
Al K. Hall
vidoman,
Thank you for the reply.
I know that the product works, and that Asus has an OEM license for the bundled software. The issue is the the fact that the activation process cannot 'find' IE.
No matter, I will uninstalling the Intervideo software and going with Nero.
