Does anyone know where I can find some info about compressing a video for view on the web. I am using Ulead 11+, and when I create my video for the web, it takes 4 -5 minutes to stream before you can view it. It has both audio and video. I am using the Sorenson 3, to create the .mov.
My video is about 3 minutes long.
Yes, I know that I need to view the forum but there are over 200 pages and I do not have the time to find the one that will help.
All I am asking is for some information about compressing my video.
Any info is greatly appreciated.
Thanks JK
Compression
The filesize is determined by bitrate (and playing time). A lower bitrate will give you a smaller file (and lower quality).
You can use the following formula to estimate file size:
File Size in MB = (Bitrate in kbps x Playing Time in minutes) / 140
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Ulead Video 11+ Compression
Got your response, not quite what I am looking for.
What I need is some insight to the different compression for audio and video within video 11 interface. It has 24 bit integer, streaming, and the video size, for example. How do I know what to use if it is not explained. This is what I am looking for an explanation about the output of a video.
Could you direct me in this direction.
Thanks JK
Thanks JK
What do you mean by "for the web"? Are you going to put it on a webpage? On YouTube? Make it available for download?...my video for the web... to create the .mov... What I need is some insight to the different compression for audio and video within video 11 interface. It has 24 bit integer, streaming, and the video size, for example.
I don't have Video Studio on this system, and I don't know what the MOV options are... Maybe someone else will jump-in and explain the options.
If you don't understand the terminology, there is a glossary at afterdawn.com, or you can check Wikipedia, etc.
There are many different formats and many variations/options for each format. The exact format details are constrained by the play back software/system. For example, if you are making a DVD, there are very specific requirements. On the other hand, if you are going to play it on your computer, you can use any format for which you have a CODEC. If you want it to play on many different computers, then you need to use a common-computer format like WMA, or make sure that each user's computer has the correct software or CODEC. If you are uploading the video to a site like YouTube, they have their standards & requirements listed on the site.
No time to think.
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
That doesn't get you far on an all volunteer web board...Yes, I know that I need to view the forum but there are over 200 pages and I do not have the time to find the one that will help.
Simply in VS when you're going to produce your video file, (Share>Create Video File), select Custom, then in the Save As File Type drop down, select the QuickTime (MOV) format. Then press the Options. You can find several Codecs including Sorenson. I just ran a quick test using the video samples supplied in VS.
I used Sorenson Video CODEC, Quality-80%, 24bit Color Depth, then in there is a box beneath this Prepare for internet streaming. Place a check in that box, and the drop-down menu is activated. From that make your choice. I would use the Fast Start. Then choose your Audio compression.
Here's the properties of one of the tests I performed:
Test Clip about 3megs.
- ram: 2 GB
- sound_card: Intel GMA 950
If you take advantage of the free upgrade to VS 11.5+ then on the share tab you have a new option to render the video in a format suitable for use on YouTube.
We have also provided a few other suggested settings as a series of stickies at the top of the Members Samples forum.
