"For ripple editing there is no gap to apply a transist
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
VS 11+.Got the above message on trying to insert a transition inbetween two images, one 7 sec long and the following one 11 secs long.Can anyone tell me why this is happening please Ken
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Well... it's very likely you are applying a transition between two clips amongst many others on the timeline during the middle of a sound track.
Adding a transition will shorten the clip...everything after that will need to move in slightly.
I usually find it's the sound (music) track that needs to be turned off ripple editing but the genral lesson here is:
to finalise all editing and transitions BEFORE turning on ripple editing.
Clevo
- ram: 4GB
hehe true.... but but...Ken Berry wrote:But Clevo, if you do everything first, and finish your editing, then you don't need ripple editing...!
what I meant was to have all the transitions done, then link up audio/overlays with ripple editing on.
I'm not sure how other NLE's handle ripple editing. But with VS you always get to that stage towards the end of working on a project where the tweaks don't work with everthing turned on in Ripple editing.
Something always have to give and I find that the minimum hassle is turning ripple editing off the music track only works most of the time.
babdi
- motherboard: ASRock Extreme 11
- processor: Intel 3770K
- ram: 32 GB DDR3
- Video Card: Asus 660TI 2 GB
- sound_card: On board Realtek
- Hard_Drive_Capacity: 6.128 TB
- Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
- Corel programs: Video studio
Kenneth,
Can you provide more information? I've tried to replicate this, and so far can not. I've loaded up the time-lines with video, audio, titles and images. When I had several on the time-lines, I then envoked ripple editing. Next I inserted a couple of images using the durations you specified (7 and 11 secs). I then inserted a transition between them. The images, titles, and audio all moved over and the transition was allowed to be inserted as is.
I tried several possibilities, such as different transitions, different durations for the transitions, but it would not refuse it. I don't know which transition you're trying to insert, and the durations, which may have an affect on this.
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Ripple Editing
Here you will see that I have described various permutations of the procedure.
Ripple Editing
Ken Veal
- ram: 32 GB
Inserting transitions with rpple editing enabled
Thanks for all the replies men
Ron.... more info-
project 27 min long so far
Images are after video.
Transistion default duration 5 secs
78 clips in storey board so far
Trying to insert trans between clip 76+77
Clip 77 has tiltle on it no o/lay or music
clip 76 has o/lay and title no music
there is no trans betwwen 75+76
75 +76 are images
clip 76 is 7 secs long
have had ripple edit enabled on all tracks all the time
have tried Roll-side...Rotate spin and stretch barn door
regards Ken
Ron.... more info-
75 +76 are images
regards Ken
